Hjelp! Opera consonance 15th anniversary med problemer
  • amason
    Hei har denne rørforsterkeren som blir glovarm på stort sett hele overflaten inkl front/volum.
    I bunn er det ingen tegn til varme. Alt fungerer, merker Inge ting på lyden men vil tro det ikke er normalt! Er det noen i Østfold som evt kan ta en titt, feilsøking etc ? NB! Den er testet frittstående med god lufting
    D
    BeetleBug
    Jeg har svart deg før vedr denne men repeterer gjerne igjen:
    Ventilation
    The equipment should be situated so that its location or position does not interfere with its proper
    ventilation.
    1. The equipment must not be placed on bed, sofa, or similar surfaces, that may block the
    ventilation openings,
    2. The equipment must not be placed in a built-in installation, such as a bookcase or cabinet that
    may impede the flow of air.
    3. The equipment should be situated away from heat sources such as radiators, heat register,
    stoves, or other electronic appliances that produce heat.
    Videre kan du lese dette:
    2. Positioning the Equipment
    The amplifier may generate considerable heat during normal operation. Please ensure that the unit is far away from effect
    of any domestic heat source and adequate air circulation around the unit is provided to maintain cool operation. For air
    circulation, leave enough space around the unit (at least 3 cm on the top and 3 cm on the sides and leave enough space
    on the back for the power cord and interconnect cables). If the equipment is going to be mounted in an enclosed cabinet, it
    is recommended that the rear of the cabinet has vents to allow air to circulate around the unit.
    With these considerations
    implemented, the equipment should then provide exceptional performance as intended. However, the usual protection of
    equipment from excessive dust and moisture should always be observed. All the equipment made by Opera Audio has
    been carefully designed with high quality components so that Long-term undiminished performance is operated in
    accordance with the instructions provided.
    amason
    Ventilation
    ventilation.
    Hei takker for den og den er nå testet frittstående på gulv med samme resultat! Som sagt så låter den normalt men kan ikke forstå at den skal bli så varm
    amason
    Hei en liten oppdatering, gitt forsterker klaring fra rack! Byttet fra kt120 til kt88 rør og nå blir den litt mindre varm! Sider, front og topp plate der rørene står blir ganske varmt men trafo delen er knapt lunken så da vil jeg vel tro det er i orden 👍
    amason
    Oppdatering! Fått svar fra Opera at den ikke skal bli så varm så de ber meg sjekke resistorer ?
    Kan dette sees eller må det måles ? Hører som sagt ikke noe på lyden og har tatt noen bilder av innmat! Også tatt bilde av bunnplate med slisser i som holder seg knapt lunken.
    Ser at rørholdere som er i keramikk er skrudd rett i chassis og de blir vel glovarme ?
    jane
    KT120 drar ca 0.2A mer glødestrøm enn KT88. For 4 stk blir dette 5-6 watt mer som omsettes til varme, så alt annet likt vil KT120 gi en varmere forsterker. Sjekket du hvilestrøm/bias etter rørbytte?
    amason
    Er auto bias
    s2a
    Det er nok riktig nå. Forsterkeren din tar kun KT88 eller 6550 rør. KT 120 eller andre Power rør kan IKKE brukes.
    Det er derfor din forsterker har blitt glovarm😉. Flaks du ikke har brent komponenter inne i forsterker.
    amason
    Ok fikk beskjed fra opera selger i Australia at de får sine levert fra fabrikk med kt120 rør men mulig de er justert annerledes, blir også varmt med kt88 rør men ikke fult så ille
    jane
    Er auto bias
    Nå er det mange måter å realisere auto-bias på og ikke alle tar høyde for at hvilestrømmen blir den samme hvis du skifter til en annen rørtype. Hvis du ikke vet 100% hvordan auto-biasen fungerer så er det tryggest å måle hvilestrømmen.
    Når det snakkes om varme så er det stort sett en plass det utvikles varme i en rørforsterker (foruten strømforsyningen og gløding) og det er i og rundt utgangsrørene, effekt og temperatur er proporsjonal med hvilestrømmen. Temperaturen til strømforsyningen (høyspent delen) er også avhengig av hvilestrøm. Når en rørforsterker blir ubehagelig varm, er det alltid lurt å se om hvilestrømmen er innfor spec.
    s2a
    Nå er det vel slik at Osborn får Consonance til å lage spesielle versjoner til det Australske markedet. Så det er nok gjort noen forandringer i bias tror jeg
    amason
    ja Greg Osborn skulle sjekke det ut! Han viste ikke selv at det skulle være noen forskjell
    amason
    Takk til dere som bidro i denne tråden 👍
    amason
    Hei spiller har hvert oppe nå med Kt88 rør og fungert perfekt! Men skulle slå på forsterker i dag og det kom gnist/knitring fra det ene 5AR4 røret så trenger et nytt, helst et billig rør så jeg får testet at det ikke er noe annet feil så jeg håper noen har et rør liggende! 5AR4/ GZ34 likeretter rør
