Game over. Mytek Brooklyn MQA ready DAC.
The Absolute sound har testet Mytek Brooklyn DAC. Klikk på bildet for å lese testen.
Pris: 18500 Inkludert frakt.
For eiere av Stere-192 DSD DAC tilbyr vi en inbyttedeal på 12000 NOK + frakt
F
or bestilling: ring 93047149, send mail til info@moiz.no eller PM
Fra produsentens hjemmeside: mytekdigital.com
Brooklyn is a reference USB2 DAC, line and phono analog preamplifier and a reference headphone amplifier.
It integrates digital and vinyl hi-res playback for reference listening on headphones and speakers.​
SPECIFICATIONS :
CONVERSION: up to 384k, 32bit PCM, native DSD
up to DSD256, DXD, 130dB Dynamic Range
MQA HI-RES DECODER: built in certified hardware
MQA (tm) decoder
DIGITAL INPUTS: USB2 Class2 (OSX, Linux driverless,
all formats), AES/EBU (PCM up to 192k, up to DSD64 DOP), 2x S/PDIF (PCM up to 192k, up to DSD64 DOP), Toslink/ADAT 2x S/PDIF (PCM up to 192k, up to DSD64 DOP), SDIF3 DSD up to DSD256
CLOCK: “Mytek Femtoclock Generator (tm)” 0.82ps internal jitter, Wordclock Input and Output (allows stacking multiple units for multichannel operation,
includes mch DSD)
ANALOG OUTPUTS: RCA, balanced XLR, simultaneous,
50 Ohm impedance
HEADPHONE OUTPUTS: Reference High Current,
High transient Headphone Amp, 500mA, 6 Watts,
dual headphone jacks, designed to drive hard to
drive headphones.
BUILT-IN ATTENUATOR: Choice of 1dB step analog attenuator, separate for main out and head- phones,
1dB step digital 32 bit attenuator and purist relay bypass.
BUILT-IN ANALOG PREAMP: Line level input or
Phono M/M, M/C input, relay controlled.
AUDIO INTERFACE FUNCTION: All digital inputs can
be routed into computer via USB2. Allows connection
of external digital sources such as CD Players and
digitizing ADCs.
REMOTE: Included, universal remote capable
FIRMWARE: Upgradable via USB Control panel
WORLDWIDE POWER SUPPLY
OPTIONAL DC/BATTERY POWER INPUT: 12VDC
DIMENSIONS: WxDxH=8.5x8.5x1.74”=216x216x44mm
WEIGHT: 4lbs, 2kg
WARRANTY: 2 years
Volund
OSLO
Spennende, hvordan er mulighetene for hjemlån?
Moiz Audio
Moiz Audio sine annonser
Moondrop Para II
Moondrop Para II
  • 4
Nyhet fra Moondrop! Vi anbefaler PARA II hodetelefoner for audiofile som ønsker en allsidig planarmagnetisk hodetelefon til en konkurransedyktig pris. Lydsignaturen er naturlig og balansert. PARA...
AudioByte SuperVOX Multibit DSD DAC
  • 2
AudioByte SuperVox er designet for lydreproduksjon av absolutt ypperste kvalitet. DAC-arkitekturen er basert på AudioBytes egne proprietære digitale algoritmer og full balansert diskret analog...
Audiophiliac tester Lab12 DAC1 Reference
  • 18
klikk på bildet Lab12 har konstruert en ny NOS-DAC som overgår tidligere konstruksjoner. Den heter DAC1 Reference. Produktet har et no-sampling, no-upsampling design kronstruert rundt Philips...
Hi-Fi+ har testet Heed Audio LaGrange S
  • 6
Sjekk ut omtalen her: https://hifiplus.com/articles/heed-audio-lagrange-s-integrated-amplifier/ LaGrange S er den nye referanseforsterkeren fra Heed Audio. Forsterkeren er basert på TransCap...
Lab12 Integre4 MK2 Toroid
  • 3
Integre4 MK2 fra Lab12 er en forfinet oppgradering av den opprinnelige forsterkeren. Ikke bare leverer den mer effekt, men den skilter også med forbedret klarhet, imponerende dynamikk og styrke...
Staccato Audio :Open Sound Hybrid Discrete Op-amp
Open Sound Hybrid Discrete Op-ampene fra Staccato Audio er designet for å oppgradere lyden i high-end DAC-er, RIAA og forforsterkere. OSH Op-ampene har J-FET i både inngangs- og utgangstrinnet...
