Igjen, og fremdeles så får EMT's 928 II en Klasse A ranking i Stereophile.
"EMT 928 II: $9995 without tonearm, $14,995 with EMT 909-HI tonearm, $17,995 with tonearm and EMT JSD Pure Black phono cartridge
KM auditioned this belt-drive, three-speed, battery-powered turntable with EMT’s 909-HI 9" static-balance tonearm and EMT’s JSD Pure Black phono cartridge. The first qualities he noticed with the player powered with AC were “a banging sense of drive and impressive note-by-note resolution. Regardless of what phono stage or amplifier I used, it played music forcefully and subtly, capturing not just forceful rhythm but also the soundstage cues that make music sound real and alive and the intricate shifts of attention and focus that convey the presence of living, breathing musicians.” Changing to battery power, he found that piano and drums became cleaner and somehow lighter while bass became weightier and better defined. “The most surprising thing was that the music sounded louder, more upfront,” he commented. (Vol.47 No.9 WWW)"
Pris med EMT 909 HI arm 176.640,-
Noe som gir et avslag på ca. 11.000,- på armen.
EMT 928 II
Product Flyer | Manual
The EMT 928 II is a massive built precision turntable with an overall weight of 23kg. The chassis is machined from aluminium, resting on four decoupled, spherical feet.
The device features an independent battery power source, so any interference from the power grid is excluded. The built-in charger circuit handles the charging cycles automatically and shows the status with a two-colour LED.
A most modern 20 Watts motor speeds up the 5,5kg platter in a short time and keeps the speed constant within a narrow tolerance-field.
EMT 928 II
Platter speed: | 33⅓ / 45 / 78rpm |
Wow and flutter: | ±0,07% (IEC 386) |
Rumble: | -85dB (IEC 98) |
Speed-up time: | 10 / 12 / 20s |
Battery service life: | 40 / 38 / 30h |
Dimension: | 480x340x100mm |
Weight: | 23kg |
Input voltage: | 100-240VAC, 50-60Hz |
Output terminal: | RCA, with separated tonearm ground |
Mounting distance arm: | 215-245mm, prepared for EMT 9-inch tonearm |
239.4 KB Visninger: 68
85.6 KB Visninger: 69
