Dinosaur Jr Too Loud....
2m
Skien...
Saksa fra http://www.dinosaurjr.com/
European Farm CD Audio Problem
Dear Dinosaur Jr. Fans,
Please note that on the European CD version of the Farm album there is an audio problem. This occurred while duplicating the original master in a duplication studio. The problem occurred when the duplicate was produced, as the software program used for this duplication ‘doubled’ the sound layers. This resulted in a 3dB increase in the overall sound volume.
If you have bought a CD of Dinosaur Jr.’s Farm album in a European shop with the bar code number 5414939004926, and you would like to exchange it with a good version, please go the site mentioned below. There you will find more information on how you can see if you have a copy that has this sound problem and how you can get a new copy of the album. Both PIAS and the band would like to offer the fans something extra for this inconvenience, so in addition to a replacement CD, PIAS will email you a link to download an "Over It" Ringtone once they have
received your bad copy. A valid email address is required to receive the ringtone. PIAS is now going to cover postage both ways to make this exchange easier and less of an inconvenience for our fans. Once you've sent in your bad CD PIAS will include the same amount of stamps, used on your package to get the bad CD to PIAS, in with your replacement copy of Farm. Again, we apologize for this issue and inconvenience. Please go to: http://media.pias.com/dinosaurjrfarmcd for more info.
PIAS
Er det noen som har merket dette "problemet"? Har vært litt sent ute med bestillinga av DJ siste. kommer i posten i løpet av et par dager. Får se da hvilken versjon jeg får (bestilt fra Play.com)
Roberten
Dersom du bestilte 2cd delux edt. er det ikke noe problem, den er uansett problemfri.
Jeg vil vel også tro at siden du bestiller såpass sent så har distributøren fått ordnet opp slik at du får en korrekt versjon.
Uansett så vil du merke det rimelig greit dersom du får en cd med denne feilen, jeg kjøpte den på gøy og var rimelig overrasket over hvor godt den merkes. Alt vrenger og det er nokså ubehagelig å høre på i lengden.
mikefish
merket dette "fenomenet" på mitt eksemplar også.har ikke dvelet så mye over dette,men det er noe irriterende å måtte skru ned volumet.
mvh. s,
2m
Skien...
Bestilte ikke deluxe versjon dessverre, men får håpe distribitøren har fått fjernet cdene med feil. Jeg vil jo uansett merke det
Roberten
Det er såpass lenge siden feilen ble kjent at jeg ville blitt overrasket om du ikke får en som er i orden.
2m
Skien...
Fikk omsider plata fra Play (de sendte bekreftelse på at den var sendt 16.08) idag. Gjett hvilken utgave jeg fikk....
Joda, den med feil. Play har i allefall ikke fått "rydda" i lageret.
