Digital Speilreflex
Bjørn.H
Da er tiden kommet for å anskaffe et rimelig speilrefleks i tillegg til de to gamle analoge jeg har (men ikke bruker lengre).
Jeg har kommet over et Nikon D40x (oppgradert D40) som jeg lurer på om er et bedre kjøp enn Nikons D60. Jeg har planer om senere å gå til anskaffelse av et dyrere kamera fra Nikon, kanskje D90 eller bedre, og har en kamerat som med Nikon kamera med linser han gjerne vil låne ut. Noen som har noen formeninger?
Mvh. Bjørn
mteinum
Øya
D40/D60 blir vel litt hipp som happ. Noe mere MP i D60. Jeg hadde D40 og gikk til D300 for å få et hus med motor i slik at jeg kunne bruke feks. 50mm/f1.8 og andre objektiver som ikke er AFS.
coolbiz
Sydvestlandet
Fra Tom Hogans omtale (http://www.bythom.com/nikond60review.htm)
The D60 is a refresh of the D40x. The things that changed between the two cameras:
Image quality improvements. The D60 uses the EXPEED processing system, and as such it has some very modest image quality improvements, most of which don't really show up until you bump the ISO way up and pixel peep. Still, as good as the D40x was, any improvement is always welcome. The D60 seems to be a little cleaner in its images, and that's a worthy improvement.
Sensor cleaning. The D60 gets the shake-it-and-drop-it sensor cleaning that its big brothers have (D90, D300, D700), but with a twist: the airflow caused by the mirror flipping back and forth has been tuned so as to help remove dust from the sensor area. The airflow bit is, in my estimation, untestable and thus very modest at best, but the sensor cleaning function is welcome and really needs to be on this class of camera, where the user is less likely to want to open it up and do manual cleaning.
Viewfinder changes. The D60 knows when you've put your eye to the viewfinder and turns off the color LCD, removing an annoyance many had with the D40 and D40x. Oh, and the interface on that color LCD now rotates with the camera. The viewfinder also provides confirmation of focus for manual focus users.
Minor menu changes. Nikon has added a stop motion movie function, in-camera raw processing, and some additional RETOUCH menu gimics (cross star and color intensification).
Dedicated Active D-Lighting button. You can now turn Active D-Lighting on and off without dropping down into the menus.
All these changes are welcome, though none of them are earthshattering. The bottom line on the basic feature set changes is that if you liked the D40 or D40x, you'll probably like the D60 a little more.
Bjørn.H
Det kan se ut som D60 er noe forbedret og at det verdt å betale litt ekstra for oppgraderingen. Nikon D40x fant jeg brukt for 3000,- med extra batteri og veske, men D60 får jeg maed samme objektiv som er uten VR (i likhet med selgerens) for 3600,- i billigste nettbutikk, så da gir valget egentlig seg selv.
Wright
Du skal velge noe veldig, veldig rart for å få et dårlig speilrefleks for tiden. Selgeren med D40x later imidlertid til å være optimist til det absurde.
Bjørn.H
Skjønner jo at man prøver å få en bra pris for tingene sine, men uten VR optikk så er prisen for høy.
