- Ble medlem
- 04.06.2006
- Innlegg
- 178
- Antall liker
- 0
http://inguzaudio.com/RoomCorrection/
Dette såg jo kjekt ut. Nokon som har prøvd liknande?
Einaste som er aberet for meg er dette: "Performance: could be better. The system requirements specs indicate a 2GHz CPU, and this really is a realistic baseline. If you have more than one Squeezebox, each will take perhaps 20% CPU... which obviously sets an upper limit on the number of squeezeboxes which can be supported simultaneously. If your PC is used heavily for other things, then you may find that InguzDSP has a noticeable impact on the PC performance. Your mileage may vary, of course, but don't try running on a 1GHz P3; it just won't work."
Eg har ein bærbar datamaskin med begrensa datakraft. Prossessoren er på 1,7Ghz - centrino.
Uansett, dette må jo vere ein billig oppgradering av anlegget.
