Forsterkere Chromecast og dac
sagundersen
Har nylig kjøpt meg en Rotel 1572. Er interessert i å få best mulig kvalitet på musikken og ønsker derfor å bruke Tidal. Slik jeg har forstått det vil Bluetooth sette begrensninger slik at jeg ikke vil få nytte av Tidal sin gode kvalitet?
Vurderer derfor å kjøpe Chromecast Audio, men ønsker ikke å bruke DACn som er i chromecasten, men heller den i forsterkeren(denne er vel en del bedre?). Hvordan vet jeg hvilken DAC som blir brukt? Bør jeg ha en ekstern dac for at Chromecast skal være bra?
BeetleBug
God lyd fra Chromecast er ikke så enkelt som en del kanskje tror. Men gjør man det riktig og bruker en god DAC så fungerer den utmerket:
Sjekk her:
https://www.audiosciencereview.com/...ents-of-chromecast-audio-digital-output.4544/
Conclusions
There are a few here:
1. The CAST audio functionality of Google Chrome is horrid. There is no excuse for it to be butchering even simple 16-bit signals as it did. While audibly it is not as dire as it looks, I still would avoid it if you can.
2. Roon's implementation of Chromecast streaming is superb. It is bit accurate up to 24 bits and 48 kHz that I tested. Congratulations to Roon for job well done. I assume they received support from Google to implement it as the protocol otherwise is not open to the public.
3. The Chromecast output has more jitter than an audiophile/instrument grade Toslink output. This is evident when used with low quality DACs like Schiit Modi 2 Uber.
4. Using a well-designed Dac like the Topping D50, there is no difference at all between Toslink from Chromecast or higher fidelity sources. All the jitter is filtered out resulting in the performance of the DAC itself being the limit.
#4 is a great news here. It means that if you have a good DAC and use Roon, you can turn your DAC into a streamer/renderer using the Chromecast Audio. For just $35, that is a superb addition. As such, the combination of Roon and Chromecase audio is highly recommended!
-BB-
sagundersen
Hva er en god dac? Må den være ekstern, eller holde den som er integrert i Rotel 1572?
Selvom chromecasten har integrert dac, vil det likevel være den som er i forsterkeren som blir brukt?
BeetleBug
En god DAC er en som klarer å kompensere for alle jitterfeilene som Chromecast gjør. Du må gjerne prøve den innebygde du har i din Rotel 1572.
-BB-
