C.E.C. TL3N Cd drivverk & DA3N DAC
CEC har kommet med en knallsterk kombinasjon i form av Cd drevet TL3N og DAC'en DA3N. En nyhet er at de har kommet med noe som kalles superlink som separerer digitalsignalet i 4 deler. Les mer under her.
Made in Japan
CEC was founded way back in 1954, and was originally known for vinyl turntables, growing steadily into a major supplier of same, under its own brand but also as an OEM
source, until CD came on the scene during the 1980s.
The company moved naturally enough into CD player manufacture, and found a USP in the early 1990s by adopting a belt drive approach to the disc drive (and pickup drive) mechanisms.
Another unusual technique CEC applies to the TL 3N disc
CEC The drive and the DA 3N DAC is a so called 'Superlink'. This separates the digital signals into four different components, labelled MCK, BCK, LRCK and DATA (Master clock, Bit clock, L/R clock and digital data stream), and carries them between drive and DAC via four supplied
BNC terminated cables.
Using the Pulse filter throughout, the overall character of this disc drive/DAC combo is essentially sweet, kind and free from any unpleasant nasties, and if the fine detail is slightly suppressed compared to the best, marginally compromising texture information, there's no quibbling about the superior timing and presentation.
One surprise was the significant sound quality difference heard between the single-cable S/PDIF connection and the four-cable Superlink. Despite using a costly Kondo digital S/PDIF cable, the four supplied BNC-terminated Superlink cables clearly sounded superior, delivering a combination of improved dynamic vigour and a greater impression of scale.
There's no denying this combo makes a fine CD player, but of course this DAC has a plethora of other digital inputs. Rather the DA3N comes with such a huge variety of different input types it ought to be able to cater for any possible eventuality.
Conclusions
This is a very impressive two-box CD player, with lovely timing and dynamic expression plus a sweet and delicate presentation. Add in exceptional DAC input flexibility, a sensible remote handset and costeffective construction at prices well below today's high end norm, and as a result deserves my confident recommendation.
Paul Messenger | Review Hifi Critic
UK audio magazine 2013
PRIS: TL3N - 31.000,-
DA3N - 41.000,-
Kombopris - 65000,-
tom@endpointaudio.no
+47 47 83 29 22
motoren
Flekkefjord
Dette var meget flott,ikke så helt gal pris heller :)
LMC
Drøbak
det er jo bare delsignalene i I2S standarden
max 10cm kabel fra kilden
samme som usb til I2S adapterne fra Exa og WaveIo leverer til dac inngangene på DIY prosjekter som Buffalo og DDDAC1794
Leif
torem
Tyske B.M.C. har også Superlink mellom drivverk og DAC. Til alt overmål har de også remdrift og prisen er ca. den samme. Men om det er det samme systemet eller ikke skal jeg ikke mene alt for mye om. Uansett er jo dette sikkert et godt alternativ til de som vil ha en high-end combo til et 5 sifferet beløp. Mange konkurrenter havner vel fort på 6 siffer her.
LMC
Drøbak
superlink=I2S
veldig bra at de hopper over usb, s/pdif e.l.
Endpoint Audio
Endpoint Audio sine annonser
Nyhet fra Canor - Canor Virtus A3, alt i ett forsterker.
  • 2
Canor har endelig lansert sin nye alt i ett enhet. Klasse A/AB, 6 digitale innganger, 4 analoge innganger, 1 phono MM/MC inngang. I tillegg har den hodetelefonutganger i fronten - balansert og...
Black weeks hos Endpoint Audio - 15-20%
Jeg kjører tilbud på en rekke merker ut november. Horns - 20%. EMT og Thales - 15%. Canor 15%. Norma - 20%. Ring eller send mail for tilbud om det er noe du ønsker...
Lagertømming av Lumin. - 40%
Jeg har noen få Lumin U2 mini igjen på lager, og selger ut disse med ca. 40% avslag. Nå 18000,- https://perfect-sense.se/varumarken/lumin
Høstkampanje på Canor Produkter hos Endpoint
  • 2
Jeg kjører igang en høstkampanje på alle Canorprodukter. -20% på alle enhetene. Canor Audio har utviklet og produsert Hi-Fi-elektronikk i over 25 år med spesielt fokus på rørbaserte løsninger. I...
J. Sikora Reference - 1 av 4 A+ rankede i Stereophile
J. Sikoras toppspiller er også den "billigste" A+ spilleren Stereophile har ranket - Prisen er 48.000 USD (389.000,- i norge) + arm. Michael Fremer hos Stereophile har testet J.Sikora Reference...
EMT 928 II - Stereophile Klasse A Platespiller, Høst 2024
Igjen, og fremdeles så får EMT's 928 II en Klasse A ranking i Stereophile. "EMT 928 II: $9995 without tonearm, $14,995 with EMT 909-HI tonearm, $17,995 with tonearm and EMT JSD Pure Black...
