Bybee ?
paviola
Hei :)
Litt dumt av meg dette kanskje, men aner ikke hva et bybee filter er, hvordan det er bygd opp, og hva det ellers gjør med lyden.?.
Takker for bidrag :-D
BangBang
Okka by
http://www.bybeetech.com/ourtech.asp
"What Is Quantum Purification?
Jack Bybee's Quantum Purifiers were originally developed for military applications, many of which are still highly classified. These amazing devices have been used for years by knowledgeable audio and video enthusiasts to reach levels of signal purity and transparency unattainable prior to their introduction.
Within any playback system, musical and visual information is transmitted by electrons flowing through conductors. As electrons interact with the conductive materials of cables and circuits, very low-level (quantum) noises are generated. As quantum noise energy accumulates in the propagating signal, low-level details pertaining to ambience, soundstage, timbre, dynamics, color fidelity and picture resolution are obscured, robbing the presentation of vividness and life.
Bybee Quantum Purifiers operate on the quantum mechanical level to regulate the flow of electrons that make up the signal (picture a metering light regulating freeway traffic flow). Current flow within the Quantum Purifier is unimpeded and ideal (think of the unencumbered flow of traffic on a lightly traveled expressway). During transit through the Quantum Purifier, quantum noise energy is stripped off the electrons, streamlining their flow through ensuing conductors. Unwanted quantum noise energy dissipates as heat within the Quantum Purifier rather than emerging as a layer of contamination residue over the audio/video information.
The benefits of this process extend beyond the physical length of the Quantum Purifier. As electrons speed through the purifier, a "slipstream" effect is formed which facilitates current flow in the surrounding conductors of the playback system. Introducing Bybee Quantum Purification into the electron path reduces quantum noise and increases signal velocity, resulting in performance improvement beyond what is attainable by any cable alone, no matter how well designed.
Slipstream: the New Generation of Bybee Quantum Purification
In 2003 there were breakthrough developments concerning the theoretically ideal materials and physical form needed to optimize noise reduction and electron flow through the signal path. Advances in materials science and fabrication technology have resulted in a unique new carbon fiber-based Quantum Purifier with electron noise reduction and electron Slipstream transmission properties that are distinctly audible and visible, and superior to Jack Bybee’s earlier developments. The Bybee Slipstream Quantum Purifier represents the Quantum Purifier concept taken to the limit. Slipstream Quantum Purifiers are now available in three versions—with copper, silver or gold leads—for optimal performance in different components and applications.
Golden Goddess: The Gold Standard in Conductive Material
The new Bybee Slipstream Golden Goddess products are the culmination of decades of research and development by Jack Bybee. Over the past couple of years, the new-millennium Slipstream purifier based on carbon fiber and nanotechnology has taken the elimination of quantum mechanical noise to unprecedented levels. Eichmann RCA plugs, banana plugs and 5-way binding posts, and ERS “Stealth” carbon fiber damping and shielding material, ensure sonically superior connectivity. A new, ultra-flexible expanded Teflon (ePTFE) functions essentially as an air dielectric for the conductors, virtually eliminating capacitance. Those elements combined to make the sonics of the original Bybee Slipstream accessories and cables dramatically open, spacious and tonally pure.
Jack Bybee has now added to those materials and construction techniques the uniquely natural sonic properties of 14 K gold for the signal (+) legs of all these new products. After extensive measurements and listening tests, he has chosen to complement the gold (+) conductors with high-purity silver ribbon for the (-) conductors. This silver ribbon has lower measurable resistance than either gold or copper wire, and the gold (+)/silver (-) combination has proven to deliver the most balanced, neutral and harmonically complete performance. These Golden Goddess products are the best-performing accessories and cables Jack Bybee has ever designed.
Copyright © Bybee Technolo"
Espen R
Er en entusiast av Bybeefiltre.
Forskjellene er absolutt ikke som natt og dag, men de små forskjellene som er oppleves i mine ører som svært viktig. Har noe med fravær av støy som påvirker microdynamikken, rom, luft, nedre frekvense m.m. Jeg kommer mere "inn" i musikken med Bybee.
Anlegget ditt bør være temmelig transparent for at du skal oppleve forskjellene.
