[h=2]En ny oppgradert versjon av Burson Audio Conductor er nå tilgjengelig!
[/h]Burson Audio's Conductor Virtuoso Now Shipping
Melbourne, Australia | December 9th, 2014 | Burson Audio, manufacturer of fine USB DAC/Headphone Amplifier/Preamplifiers, Headphone Amplifiers and Stereo Amplifiers, introduces the new Conductor Virtuoso superseding all previous Conductor models.
The Conductor Virtuoso
The Conductor Virtuoso is a USB DAC, Headphone Amplifier and Preamplifier in one elegant, beautifully-built package. Many audiophiles use an outboard DAC and headphone amplifier to drive their headphones or desktop systems. The Conductor Virtuoso is a highly-engineered yet modestly-priced component with up to 4 watts of power to drive any headphone with ease. Or consumers can use the Conductor Virtuoso's preamp functions to make it the center of a headphone and speaker-based desktop system or a larger speaker system using Burson's Timekeeper power amp.
How Virtuoso is it?
Burson has significantly upgraded and refined previous generations of the Conductor. Besides big power, the Conductor Virtuoso includes a new, stunning 100-step volume control with a fresh and easy-to-read display. When the Virtuoso is turned on the volume indicators appear on the face of the thick, antiresonant aluminum front plate.
Consumers can choose from two interchangeable DAC boards with different sonic characteristics, and the modular design makes for no-fuss upgrades. Another important consideration is Burson doesn't use densely-packed opamps but instead all discrete circuitry for superior tonality, clarity and a lower noise floor. The remote control is worthy of the Burson badge, carved from solid aluminum with no visible screws.
The touch and feel of Burson products matches their irresistible sound. They'll pull you into the music in a visceral, exciting way for a lavish musical experience.
The Conductor Virtuoso is shipping now with the ESS9018 Sabre DAC at €1,850 Euros. The Burr Brown PCM1793 version is priced at
€1,451 Euros.
[h=2]The Conductor Virtuoso[/h] The Conductor Virtuoso is a USB DAC, Headphone Amp and Preamplifier. Most enthusiasts use its DAC and amplifier to drive their prized headphones with one beautifully-built, modestly-priced component. With over 4 watts of power on tap the Conductor Virtuoso will drive any headphone with ease. The Conductor Virtuoso’s headphone amp section is essentially the Soloist which reviewers have raved about. Or use the Conductor Virtuoso’s preamp functions to make it the center of a headphone and speaker-based desktop system with headphone option.
[h=2]How Virtuoso is it?[/h] Burson has significantly upgraded and refined previous generations of the Conductor. There are now a stunning 100-steps of volume control with a new, easy-to-read display. When the Conductor Virtuoso is on the volume indicators appear on the face of the thick, antiresonant aluminium front plate.
You can choose from two interchangeable DAC boards with different sonic characteristics and the modular design makes for no-fuss upgrades. As always, Burson eschews densely-packed opamps and designs all discrete circuitry for superior tonality, clarity and a lower noise floor.
DAC Options: ESS9018 DAC or PCM1793 DAC
The remote control is worthy of the Burson badge, carved from solid aluminium with no visible screws. The touch and feel of Burson products matches their irresistible sound that pulls you into the music in a visceral, exciting way.
[h=2]Cleaner Power Means Higher Resolution[/h] Ever notice how your system sounds better in the evening or weekends? Learn More [+]
[h=2]The Vault[/h] Sometimes called the Vault by our customers, the 6mm Resonance Free Aluminum (RFA) enclosures are constructed from precision-machined panels. Learn More [+]
[h=2]Measurement[/h] Input impedance: 36.5 KOhms
Frequency response: ± 1 dB 0 – 50Khz
Signal to noise ratio: >96dB
THD: <0.03% at 30ohm with 1W ouput
Channel separation: >73dB
Output power: 4W at 16 Ohms
Input impedance: >8K Ohm @ 1W
Output impedance: 30 Ohm
Power dissipation: 35W internal, regulated power supply
[h=2]DAC Specification[/h] Channel Separation: 140 dB @ 1KHz, 130 dB @ 20KHz
THD+N: 0.0005% @ 1KHz, 0dBFS
COAX & Toslink / SPDIF : 24 bits / 44.1K, 48K, 88.2K, 96K, 176.4K, 192KHz
[h=2]USB Specification[/h] OS Requirement: Windows XP, Windows Vista, Windows 7, Windows 8, Mac OS X
USB : 24 bits / 44.1K, 48K, 88.2K, 96K, 176.4K, 192KHz
Support up to 24bit @ 192Khz with 10ppm low jitter clock
Asynchronous Transfer Mode
[h=2]Inputs[/h] 1 x USB Connection
1 x Coaxial RCA (Support up to 24bit @ 192Khz)
1 x Toslink / SPDIF (Support up to 24bit @ 192Khz)
1 x RCA line level input
[h=2]Outputs[/h] 1 x headphone jacks 6.35mm
1 x RCA Pre out
1 x RCA DAC out
[h=2]General[/h] Weight: app. 6 kg
Colour: silver anodized aluminium
Dimensions: 265 x 255 x 80 mm
[h=2]Package includes[/h] 1 x Conductor Virtuoso
1 x Power cable
1 x RCA pair input cables
1 x USB cable
1 x Remote control
How Virtuoso is it?
€1,451 Euros.
1 x RCA Pre out
1 x RCA DAC out
1 x Power cable
1 x USB cable
1 x Remote control
28.3 KB Visninger: 746
