Blue Horizons etterlengtede rack system er endelig leveringsklart!
"Key Features:
– Unique triple layer mixed grain direction bamboo breaks up shelf standing waves; solid machined stainless steel acts as shock spot for draining resonance without adding sonic signature
– Solid stainless steel parts give you the flexibility in height spacing to accommodate all sizes of audio electronics. Three shelf rod lengths available
– The sophisticated design allows you to create a unique rack that fits your style and space·
– Sanctum isolation platforms fit neatly under all audio components, protect the rack finish as well as improving component perfourmance
– Elegant cable management system keeps loose wire under control and allows signal and power cable to be kept separated
– Easy to assemble, adjust and tighten, no special tool required
– Available in single and double shelf; Single: 550x450x3mm, double 600x450x30mm (WxDxH)"
Disse kan selvsagt besiktiges i våre lokaler i Dronning Mauds Gate 1-3 og ønsker du en demo, ta kontakt på:
info@oslohificenter.no
eller
22 01 04 30
For mer informasjon se:
BLUE HORIZON PROFESSIONAL RACK SYSTEM
"Key Features:
eller
22 01 04 30
231 KB Visninger: 459
238.2 KB Visninger: 472
276.3 KB Visninger: 470
186.1 KB Visninger: 448
104.8 KB Visninger: 439
268.8 KB Visninger: 503
304.8 KB Visninger: 469
