Mobiltelefon og lesebrett Bærbar musikkavspiller
OMF
Hei!
Lurte på om tenåringsjenta her i huset skulle få en musikkavspiller til jul.
Bærbar, fancy, mulighet til å spille Spotify, Dab radio og musikkfiler.
MEN - skal helst ikke være mobiltelefon, ei heller mulighet til Facebook, instagram, youtube og slikt.....
Finnes dette....?
OMF
BT
Tenåringsjente uten mobil? Det trodde jeg kun var en teoretisk mulighet.
OMF
Mobilen er på plass ,men den skal ligge i stuen om natten, men vil at hun skal ha mulighet til å spille musikk om kvelden, men ikke fikle på mobilen!
OMF
Gubra
Vær glad så lenge hun bare fikler på mobilen.
D
Desillusjonert
NWZ-F886 | Walkman Digital Music Players | Sony UK
Sony Walkman NWZ-F886 32GB - MP3-spiller - Finn lavest pris, test og informasjon
Next-level sound with High-Res Audio - The advanced S-Master HX Digital Amp reduces noise and distortion across all frequencies, so you can hear each track in rich, high-res detail
Music as it should be with DSEE HX technology - DSEE HX* injects more life into your music, upscaling your sound as well as restoring high-range sounds lost in the compression process
Music as you like it with Clear Audio Technologies - Enjoy notes in crisp, clear sound, exactly as the artist intended, with Clear Bass, Clear Stereo, and Clear Phase
A sound experience like no other with ClearAudio+ - Delivers sound in ultimate clarity and presence, across the entire spectrum
Nothing but music with Digital Noise Cancelling - Block out traffic noise, sirens and everything else – all you'll hear is your music
All it takes is one touch with NFC - Place your Walkman® against NFC-enabled speakers, headphones or Hi-Fi to establish a connection and hear instant sound
Listen out loud with xLOUD™ - Share your music experience with others, with a built-in speaker system that makes a big sound
Compatible with FLAC and Apple Lossless formats - Hear sound that stays true to the original recording. You can listen to your tracks in high-quality FLAC and Apple Lossless formats
Everything’s at your fingertips - Enjoy music, apps, and games on a bright touchscreen, or skip, play, and pause songs using three buttons on the side of the Walkman®
Connect without wires - Download apps and stream content via Wi-Fi, or connect with other Bluetooth® devices like headphones and speaker docks
Power your entertainment with Android - Enjoy pre-installed apps, games, and more from an ever-growing choice at Google Play™
Enjoy natural colours on a Triluminos display - Enjoy a wide spectrum of colours, like hard-to produce reds, greens, and blues, exactly as you see them in the real world
Listen for even longer - Enjoy up to 35 hours of battery life, so you can always listen to your favourite playlist on the go
See things clearly with an OptiContrast™ panel - The touch panel has been brought closer to the display for even clearer viewing in direct sunlight
Match the music to your mood - SensMe™ sorts your music into themed channels to suit any mood, from a relaxing wake-up to an energetic workout Works with your Mac - The new Walkman® series is officially compatible with Mac OS and iTunes high-quality sound formats – including ALAC
PS: denne har jeg lyst på selv....
