AXIOM - the real state of the art!
the Axiom fra Acoustical Systems!
En av markedets absolutt beste tonearmer.
Pris fra 148.000,-
Exclusive features of the AXIOM:
* VTF (vertical tracking force) non-touch-adjustment: on-the-fly - during play.
* SRA adjustment is independent from tonearm height (fixed mounting head)
* dynamic tunable effective moving mass
- from 22 gr to 42 gr effective moving mass in fixed mounting version.
- from 29 gr to 48 gr effective moving mass in SME-bayonet version.
* dynamic antiskating
- w/exchangeable inserts for any tangential curve!
* carbide hardend titanium / carbon-composite arm pipe with
internal liquid dampening on whole inner surface.
* exchangeable inserts in counterweight tuned to cartridge's compliance.
Thus eliminating low frequency resonance peak.
* the AXIOM and it’s bearing axis can be precisely leveled on it's own. This is independent from the plinth's level and done with 3 precision set screws around the center mounting screw (these are covered by the large round metal cap and not visible when mounted).
All these features listed above you will find in the AXIOM only.
General features of the AXIOM:
* the AXIOM is a full dynamically balanced design
* the AXIOM is a full lateral balanced design
* the AXIOM is a special 12" design with mounting distance of 9-10" tonearm
tom@endpointaudio.no
47832922
Endpoint Audio
Endpoint Audio sine annonser
Nyhet fra Canor - Canor Virtus A3, alt i ett forsterker.
  • 2
Canor har endelig lansert sin nye alt i ett enhet. Klasse A/AB, 6 digitale innganger, 4 analoge innganger, 1 phono MM/MC inngang. I tillegg har den hodetelefonutganger i fronten - balansert og...
Black weeks hos Endpoint Audio - 15-20%
Jeg kjører tilbud på en rekke merker ut november. Horns - 20%. EMT og Thales - 15%. Canor 15%. Norma - 20%. Ring eller send mail for tilbud om det er noe du ønsker...
Lagertømming av Lumin. - 40%
Jeg har noen få Lumin U2 mini igjen på lager, og selger ut disse med ca. 40% avslag. Nå 18000,- https://perfect-sense.se/varumarken/lumin
Høstkampanje på Canor Produkter hos Endpoint
  • 2
Jeg kjører igang en høstkampanje på alle Canorprodukter. -20% på alle enhetene. Canor Audio har utviklet og produsert Hi-Fi-elektronikk i over 25 år med spesielt fokus på rørbaserte løsninger. I...
J. Sikora Reference - 1 av 4 A+ rankede i Stereophile
J. Sikoras toppspiller er også den "billigste" A+ spilleren Stereophile har ranket - Prisen er 48.000 USD (389.000,- i norge) + arm. Michael Fremer hos Stereophile har testet J.Sikora Reference...
EMT 928 II - Stereophile Klasse A Platespiller, Høst 2024
Igjen, og fremdeles så får EMT's 928 II en Klasse A ranking i Stereophile. "EMT 928 II: $9995 without tonearm, $14,995 with EMT 909-HI tonearm, $17,995 with tonearm and EMT JSD Pure Black...
