Aurender X-Pac
connaisseur
[h=6][/h]
Just add speakers to the Aurender X-PAC to make an easy to set up, yet powerful audio system that makes
browsing and playing up to 10,000 CDs worth of high resolution audio fun and easy.​
[h=1]Main Features[/h]
  • Playback from SSD cache
  • 6TB storage capacity ( 12 TB model is also available )
  • Elegant machined aluminum chassis
  • Designed for quiet operation
  • Proprietary Aurender App packed with powerful features
  • Volume Control and Input Selection using the Aurender Conductor iPad App.
  • Supports all major high resolution audio formats
  • Plays up to 24/192kHz, DSD64/128 in native mode
  • Auxiliary optical SPDIF input ( Useful for connecting additional audio sources, including Blu-ray players. )
  • Power Rating : 100W per channel at 8 ohms , THD+N 0.01%
  • Remote Internet Technical Support
[h=3][/h][h=3]Aurender App[/h]
The Aurender App turns the iPad into a versatile
user interface for Aurender Music Players and
makes managing, viewing and playing high
resolution music collections a breeze.
All settings and functions of the Aurender Music
Player can be easily accessed through the Settings
menu of the Aurender App.
[h=3][/h][h=3]X725 Specification[/h]
Model NameX725 USB DAC & Amplifier
User InterfaceIR Remote Controller, Aurender App ( via X100 ), Volume Knob
​Volume Control Range-95dB ~ 0dB​
Output Power​2 x 230W @ 1% THD+N, 4ohm​ Use 8 ohm ratings only...
​Frequency Response20Hz ~ 20kHz ( <+/-0.5dB )​
Digital I/O​1 Audio USB, 1 Optical SPDIF​
Analog I/O​Stereo Speaker Output​
​Dimension (Weight)​215 x 55 x 355 mm ( 4.7kg ) / 8.5 x 2.2 x 14.0 inches ( 10.4 lbs )
[h=5][/h]
[HR][/HR] [h=3][/h][h=3]X100 Specification[/h]
User SoftwareAurender App for iPad/iPad Mini
Supported Audio FormatsDSD* (DSF, DFF), WAV, FLAC, AIFF, ALAC, APE, MP4, others
Bit and Sampling RatesPCM: same as DAC specifications; DSD: 1-bit, 2.8MHz (DSD64); 1-bit, 5.6MHz (DSD128)
​Solid-State Drive​1 x 120GB
​Hard Disk Drives​Aurender X100L (2 x 3TB) / Aurender X100S (1 x 1TB), 12TB model is also available for X100L
​Digitial Audio Outputs​1 dedicated USB Audio Class 2.0 with proprietary power circuitry
​Digital I/O1 Gigabit LAN, 2 x USB 2.0​
​CPU Power SupplyFan-less 100W SMPS​
​CPU BoardProprietary Aurender Board​
Main Memory​4GB
​FinishSilver​
​Dimensions​Aurender X100L (215mm x 83mm x 355mm) / Aurender X100S (215mm x 83mm x 257mm)
Weight​Aurender X100L (7.5 kg) / Aurender X100S (5.0 kg)
[h=5][/h]
[h=6]* DAC must support DSD over PCM (DoP) version 1.2. Only plays uncompressed DSD (No DST)
Specifications are subject to change without notice.[/h]Kontakt for salg
Connaisseur AV
Sandgaardsvej 31, DK-7400 Herning
CVR# 29 80 08 04 Phone: +45 9626 8046 (Monday - Friday)
Fax: +45 9626 8045 (08:30 - 16:30 GMT +1)
Mail: info{at}connaisseur-av.eu
gismo
Væssia i Grue.
Som andre har vært inne på, priser hadde vi satt pris på;)
Gismo
connaisseur
Hej
Der er ingen Forhandler i Norge pt, men vi hjælper gerne med alt.
Priser er ikke offentliggjort endnu, men de generelle og
vejledende priser forventes at ligge på:
N100 – kr. 18.500,-
X725 – kr. 18.500,-
X-Pack (X100L + X725) – kr. 44.500,-
Kontakt os for en superintropris!
Vi kan også lave en god pris på et samlet system, evt medGauder’s Arcona serie.
