Aurender N100
connaisseur
[h=6][/h]
[HR][/HR][h=3][/h][h=3]N100[/h]
The Aurender N100 digital music player supports
DSD (DSF, DFF), WAV, FLAC, ALAC, APE, AIFF, M4A
and other major formats at native bit and sampling rates.
Equipped with a high performance USB digital audio output,
Ethernet port, 120GB solid-state drive for cached playback,
the N100 is the ideal solution for playing
high resolution digital music collections from NAS.
[h=1]Innovative Technology[/h]The N100 digital music player incorporates many innovations originally developed for the higher priced Aurender S10 and W20 models, including a solid-state drive cache for playback which eliminates latency and drop-outs from NAS drives. The high performance USB digital audio output was developed using the same engineering as the USB outputs on the flagship Aurender W20.
[h=3]Gigabit Ethernet LAN Port for Network Connectivity[/h]For network connectivity, streaming, upgrades and file transfers, the N100 has a Gigabyte Ethernet port along with two USB 2.0 data ports for copying files from USB memories.
[h=3]Aurender App with Convenient Features[/h]The Aurender Condutor App turns the iPad into a versatile user interface for Aurender Music Players and makes managing, viewing and playing high resolution music collections a breeze. All settings and functions of the Aurender Music Server/Player can be easily accessed through the Settings menu of the Aurender App.
Android App(Lite Version) is also available.
[h=3]AMM(Aurender Media Manager) - cover art & other meta-tag support for contents on the NAS[/h]The Aurender Music Server/Player series could play contents on the NAS by file/folder browsing. With the help of AMM for PC/Mac, N100 and all other existing Aurender Music server series can display and use meta-tag information of the contents on the NAS the same as the content in the Aurender's internal Storage.
[HR][/HR]
[HR][/HR][h=2]Aurender App[/h]
[HR][/HR][h=3]Network streaming with Solid-State Drive Cache for Playback[/h] If a selected song or album is already cached to the solid-state drive, N100 will play from the internal SSD. This minimizes wear and tear on the NAS drive. Also, by caching songs to the solid-state drive for playback, it eliminates music quality degradation or even drop outs of music due to non-optimal network connection from the NAS to the streamer.
[h=3]Dedicated USB Audio Class 2.0 Output with Noise Free Power Circuitry[/h]The dedicated USB Audio Class 2.0 output is designed to deliver an exceptionally transparent audio signal free of noise and is shielded from outside electronic interference.
[h=3]Full Linear Power Supply[/h]A full linear power supply provides clean and stable power to the CPU circuit and audio output circuit.
[h=3]Remote Internet Technical Support[/h]Sending a Remote Support Request using the Aurender Conductor App allows engineers to quickly diagnose and fix problems over the Internet, should they occur.
[h=3][/h]
[h=3][/h][h=3]Specification[/h]
User SoftwareAurender App for iPad/iPad Mini
Supported Audio FormatsDSD* (DSF, DFF), WAV, FLAC, AIFF, ALAC, APE, MP4, others
Bit and Sampling RatesPCM: same as DAC specifications; DSD: 1-bit, 2.8MHz (DSD64); 1-bit, 5.6MHz (DSD128)
​Solid-State Drive​1 x 120GB
​Digitial Audio Outputs​1 dedicated USB Audio Class 2.0 with proprietary power circuitry
​Digital I/O1 Gigabit LAN, 2 x USB 2.0​
​System Power Supply35W Linear Power
​CPU BoardProprietary Aurender Board​
Main Memory​4GB
​FinishSilver​
​Dimensions​​215 x 55 x 355 mm
8.5 x 2.2 x 14.0 inches
Weight4.6kg
10.14lb
[h=5][/h]
[h=6]* DAC must support DSD over PCM (DoP) version 1.2. Only plays uncompressed DSD (No DST)
Specifications are subject to change without notice.[/h] Kontakt for sale
Connaisseur AV
Sandgaardsvej 31, DK-7400 Herning
CVR# 29 80 08 04 Phone: +45 9626 8046 (Monday - Friday)
Fax: +45 9626 8045 (08:30 - 16:30 GMT +1)
Mail: info{at}connaisseur-av.eu
OlaR
Priser hadde jo vært interessant... ;)
Petterone
Rogaland
yepp ......en selvfølge nå man reklamerer for disse produktene på ett forum som dette
connaisseur
Hej
Der er ingen Forhandler i Norge pt, men vi hjælper gerne med alt.
Priser er ikke offentliggjort endnu, men de generelle og
vejledende priser forventes at ligge på:
N100 – kr. 18.500,-
X725 – kr. 18.500,-
X-Pack (X100L + X725) – kr. 44.500,-
Kontakt os for en superintropris!
Vi kan også lave en god pris på et samlet system, evt medGauder’s Arcona serie.
