Audio-Technica AT-LP5 er en attraktivt designet hi-fi platespiller som holder en meget høy klasse uten å koste en formue!
AT-LP5 er en direktedrevet platespiller utstyrt med en kraftig motor og kommer med en presisjonsprodusert aluminiumsplate som reduserer resonanser fra spillerens chassis. At-LP5 er utstyrt med AT95EX Dual Moving Magnet Cartridge.
LP5 er en hi-fi platespiller tilbyr en opplevelse langt utover hva kundene kan forvente til den prisen!
Audio-Technica har over 50 års erfaring innen markedet for platespillere og er en anerkjent produsent av High-end pickups siden 1962!
Pris: 4495 NOK
produktet kan bestilles via epost: info@moiz.no , pm eller mobil: 93047149
Info fra produsenten:
Introducing the Audio-Technica LP5
A perfect balance of technology and design, the sleek contemporary lines of the AT-LP5 turntable grace any room in the home, while delivering performance features born out of Audio-Technica’s rich analog heritage.
The direct-drive engine provides playback for both 33 1/3 & 45 RPM records, with a cast aluminium platter and thick damping mat housed together in a structure that has been engineered for minimum chassis resonance, while skillfully retaining the discreet look that complements today’s listening environments.
The J-shaped tonearm, engineered to minimise tracking error, harks back to the original Audio-Technica designs of the 1960’s & 70’s, complementing the AT-LP5’s clean lines, and comes fitted with Audio-Technica’s lightweight AT-HS10 headshell and the exclusive AT95Ex Dual Moving Magnet cartridge.
Including:
· Exclusive Audio-Technica AT95Ex Dual Moving Magnet stereo cartridge
· Original J-shape tonearm design
· Cast aluminium record platter
· Heavy rubber material damping mat
· Sleek matt black surface finish
The AT-LP5 offers a built-in switchable phono/line pre-amplifier that provides connection to a stereo system equipped with either phono or line-level inputs. The AT-LP5 also includes Audacity recording software for MAC or PC, USB cable and an RCA / RCA stereo adapter cable, allowing direct connection to your computer to transfer your classic LP collection to digital files using its USB output.
Box accessories included
· Audio-Technica LP5 Turntable
· AT-HS10 Lightweight Headshell with gold-plated u-shaped connectors
· Heavy rubber mat
· Platter (under the turntable)
· Counterweight (accessory section)
· Power cable
· USB cable
· Dual RCA (male) to dual RCA (male) stereo cable with grounding line
· 45 RPM adapter
· Cartridge alignment and overhang adjustment template
· Audacity recording software (CD)
Optional Accessories:
· AT-LP5DT dust cover with mounting hardware
Turntable Specifications
- Type: 2-Speed, fully manual operation
- Motor: DC motor
- Drive method: Direct drive
- Speeds: 33-1/3 RPM, 45 RPM
- Turntable platter: Die-cast aluminium
- Starting torque: >1.6 kgf.cm
- Braking system: Electronic brake
- Wow and flutter: < 0.2% WRMS (33 RPM)
- Signal-to-noise ratio: > 50 dB
- Output Levels: “PHONO” (Pre-amp bypassed) - 4 mV nominal at 1 kHz, 5 cm/sec
“LINE” (Pre-amp engaged) - 150 mV nominal at 1 kHz, 5 cm/sec - Phono Pre-amp gain: 36 dB nominal, RIAA equalized
- USB function: A/D, D/A - 16 bit 44.1 kHz or 48 kHz USB selectable
Computer interface: USB 1.1 (or higher) compliant Windows XP, Vista or MAC OS X
- Type: Static balance shaped tonearm
- Effective Length: 247mm
- Typical Overhang: 17mm
- Maximum tracking error angle: Less than 2.5° curve
- Stylus pressure adjustment range: 0 to 2.5 g
- Applicable cartridge weight range (including headshell): 15 to 20 g
- Power supply requirements: 230V AC, 50 Hz
- Power consumption: 6W
- Dimensions: 450.0 mm (17.72”) W x 352.0 mm (13.86”) D x 157.0 mm (6.1”) H
- Weight: 10.5kg
- Accessories included: AT95EX Dual Moving Magnet stereo cartridge with replaceable stylus; Exclusive AT-HS10 Lightweight Headshell; AC line cord; dual RCA (male) to dual RCA (male) stereo cable; 45 RPM adapter; USB cable; recording software
- Cartridge Model: AT95EX
- Cartridge Type: VM Design Stereo Dual Moving Magnet
- Recommended load impedance: 47,000 ohms (when using external PHONO preamp)
- Output voltage: 4 mV (at 1 kHz, 5 cm/sec)
- Stylus Elliptical: 0,3 x 0,7 mil
- Tracking force range: 1.5 to 2.5 g (standard 2 g)
- Cartridge weight: (AT95Ex) 5.7 g
- Headshell model: AT-HS10
- Headshell weight: 10g
- Headshell overhang adjustment: ± 5 mm
- General Specifications: PC or Mac with an available USB port (USB 1.1 or higher) Mac running OS X 10.4 or later or PC running Windows (Vista and above)
- Installation: CD-R or CD-RW writer for burning CDs & software installation. Includes Audacity software for PC & Mac users
29.3 KB Visninger: 2.506
19.2 KB Visninger: 2.390
32.4 KB Visninger: 2.461
