Atma-Sphere Novacron MKIII.1
Disse mono blokkene var første gang produsert i 1991. Det var den første usa produserte forsterkeren som brukte de russiske 6C33C rørene. Nå er den tilbake i en ny og forbedret versjon (MK III.1). Den er nå like driftsikker som resten av Atma-Sphere serien. Den har det velkjente Atma-Sphere lyd signaturen og det klassiske Atma-Sphere designet. En kjempe spennende OTL forsterker(Output TransformerLess)!
Loddefjord HiFi. Atma-Sphere Novacron
Atma-Sphere music systems, inc.
http://www.facebook.com/LoddefjordHiFi
kr 125.000,-
Referanse kunder søkes til Novacron, ta kontakt for referanse kunde pris.
Forhandlere søkes for Atma-Sphere i Norge.
ta kontakt på: Info(at)loddefjordhifi.com eller på PM her på sentralen.
Kjetil Melvik
Loddefjord HiFi
kr 125.000,-
Balanced Differential Design® Class-A operation
Patented Circlotronic® direct-coupled (OTL) output stage
Dual-mono chassis construction
Automatic bias - no adjustment needed
Built in VU meter for tube and output monitoring
Easily monostrapped for greatly increased power
Uses only one gain stage for supreme clarity of sound
Proprietary precision components used throughout
Low-noise "star" grounding topology
Fully hand-wired point-to-point electronics - no circuit boards!
Stable with all input and load conditions
Exclusively uses Octal-Triode based vacuum tubes
Three-year general coverage warranty, one year warranty on output tubes
Output power
60 watts per channel into 8 Ω load
Impedance
Input Impedance: 100 KΩ single-ended, 200 KΩ balanced
Output Impedance: ~2 Ω
Input
3 V sensitivity
RCA and XLR true balanced input
Tube complement
4 x 6C33C power triode
2 x 12AT7 driver tube
2 x 12AU7 driver tube
Gain
23dB ( for 8 Ω )
Power Bandwidth
2Hz-75KHz within ½ dB
Frequency response
( 1 watt, open loop ) 20 Hz squarewave Tilt; unmeasureable
1Hz-200KHz within ½ dB (-3dB @ 1 MHz)
Distortion
Phase shift less than 1° @ 20KHz
Output section risetime
600 V/µs
Power supply storage
600 Joules/chassis
Power consumption
400 watts
Kjetil Melvik
Loddefjord HiFi
