Alare Labs Remiga 1
  • Ny modell fra Alare Labs , REMIGA 1 :)
    Directly derived from the larger model, the Remiga 1 follows same design features. It is a more compact floor standing loudspeaker system, but still no compromise designed for high end listening.
    The peculiar shaped transmission line bass loading has driven by two custom made woofers, a 8” (200 mm) and an 6” (170 mm) poly membrane units. Remiga 1 drivers are coupled to a tapered transmission line that provides an extremely fast, uncolored and distortion free bass experience.
    Midrange is a 5” (120 mm) unit from German Accuton Cell line, with pure ceramic membrane mounted in a volume filled with special aramid fiber wool for perfect rear emitted sound control.
    The 1.3” (34 mm) beryllium tweeter has really high power handling and a much wider dispersion pattern when compared to units of same dimension. Beryllium is an extremely light and stiff material that does a better job of maintaining high frequencies integrity and avoiding breakups. Compared to titanium or aluminum, beryllium performs significantly better.
    Remiga 1 cabinet is made from a sandwich of different woods and special damping glue layers, that together perform a very efficient “constrained layer” damping effect. This feature and an internal steel bars cage, virtually kill any vibration of the cabinet.
    Special attention has been given also to crossover board design. The best quality components are firmly mounted on a not conductive special board and connected each other with point-to-point technique, by using a silver plated solid core copper wire.
    Priser på Alare Labs Remiga 1
    Remiga 1 Beryllium Tweeter 458.300.-
    Remiga 1 Diamond Tweeter 621.300.-
    Vi søker referanse kunder på Alare Labs
    Ta kontakt for info.
    Sound of heaven
    Tlf:+47 464 29 861
    E-mail: kontakt@soundofheaven.as
    Hjemmeside: www.soundofheaven.as
sound of heaven
sound of heaven sine annonser
Takumi - priser på produkter
Da er prisene klare på Takumi :) (y) Takumi Recordplayer - Master the Moment TT Level 1.1 DC 16.500.- ( klar for markedet tidlig 2026 ) TT Level 2.1 DC 21.200.- TT Level 3.1 DC...
Demo av Franco Serblin Accordo Unica
Ønsker du en lytte opplevelse av Franco Serblin Accordo Unica? Nå har du mulighet til å booke tid for demo og nyte lyden av Accordo Unica i vårt showrom i Drammen. Pågangen har vært stor så her...
Takumi platespillere hos Sound of Heaven
Sound of Heaven har blitt norsk importør for Takumi platespillere. Vi er stolte av å kunne presentere disse vellydende nederlandske platespillerne for det norske hi-fi markedet. Mer info og priser...
Franco Serblin Accordo Unica - Demo helg
  • 4
Vi takker for oppmøte og interessen rundt Franco Serblin sin nye topp modell Accordo Unica i går og ønsker nye besøkende hjertelig velkommen for en uforglemmelig lyd opplevelse i dag. Dere...
Nytt brand hos Sound of Heaven
  • 8
Hva kan dette være, mon tro :) Sound of heaven Tlf:+47 464 29 861 E-mail: kontakt@soundofheaven.as Hjemmeside: www.soundofheaven.as
  • 1
Sound of Heaven ønsker alle hi-fi entusiaster og musikk elskere til demo helg 6-7 desember. Vi vil da lansere Franco Serblin sin nye topp modell Accordo Unica for det norske markedet. Det er...
