På leting etter noe annet enn dette, kom jeg over noe som kan være nyttig lesing:
Impedance Matching of Audio Components
Amplifier loudspeaker ohm impedance output input voltage bridging impedance no matching speakers no matching ohms speaker amp 4 - 8 - 16 resistance ohms connection of power amplifier to speakers There are no 4 ohm or 8 ohm amplifiers convert - sengpi
Measuring input impedance and calculating output impedance calculation calculate audio amplifier op-amp how to measure impedance voltage gain total loudspeaker speaker microphone resistance resistor bridging matching test load loudspeaker source resi
Speaker Impedance Explained - Ohms
Impedance, and how it affects audio equipment
