monosapiens skrev:
Jeg har sett KT88 omtalt på forumet her før og i fidelity men det sier meg ingenting.
Hva bør man vite om rør ?
Monosapiens
Jeg kan jo nevne noe som er viktig å vite om rør jeg...
Dette:
http://www.wyetechlabs.com/links/articles.html
Her finner man det aller aller meste som er av interesse!
God lesing!!!
Jeg kan jo også nevne at jeg konsekvent synes at når man skal begynne på rørbølgen, så kan man godt begynne med en integrert forsterker.
Jeg kan tenke meg at den nye Primaluna Dialogue two er ett godt valg.
"The DiaLogue Two is a KT-88 based vacuum-tube integrated amplifier, hand-made with the finest point to point wiring, using workmanship that is equal to or better than any product you can buy at any price.
The amplifier is built using finest premium parts. A toroidal transformer for the powersupply. Custom designed -in conjunction with one of the most prestigious transformer-designers in the USA- encapsulated output transformers for lowest hum, wide bandwidth for great bass and extended highs. Ceramic tube sockets. ALPS volume control. Nichicon and Solen capacitors. Gold plated heavy duty speaker terminals and gold plated input jacks. Remote control for source selection, volume and choice of Ultralinear or Triode amplification. Five line level inputs, one HT Pass Thru and one tape out. It is enclosed inside a heavy gauge steel, fully vented chassis with five coats of finish. Each coat hand rubbed and polished.
The Adaptive AutoBias circuit, an exclusive to PrimaLuna, monitors and smoothfully adjusts bias constantly and instantly, reducing maintenance and increasing performance because of a dramatic reduction in distortion. For extended life of tubes and switches plus a reduced chance of tube failure/shorts, the amplifier uses a soft-start circuit. Tube plate fusing is used to protect the output stage. Other amps might need a trip to the shop if a tube fails. Not this one. Just plug in a new tube and fuse, and go."
http://www.primaluna.nl/products_subpage1b2.htm
No fuss! Bare start å kjør! Perfekt for en uten kunnskap på rør!
