Har dac, men ønsker asynkron USB inngang = Wavelength Audio Wavelink
ceroxol
Asker
Wavelength Audio's Wavelink virker meget spennende for oss som allerede har en god dac, men ønsker å tilkoble mac/pc via asynkron USB.
http://blog.stereophile.com/rmaf2009/wavelengths_new_wavelink/
The WaveLink is an Asynchronous USB to SPDIF Converter. To keep noise and jitter low it uses a rechargeable Lithium ION battery to power these devices. Capable of 24/96 shipped with a Nirvana Audio T0 BNC-BNC cable and a BNC to RCA converter.
Ryktene sier en pris rundt $700-900.
ceroxol
Asker
Cobra2 skrev:
Spennende produkt, men når jeg leser om den så virker det på meg som at den ikke jobber asynkront, hvilket jo var poenget... Det finnes jo et utall av USB->spdif konvertere, men det er jo kun Wavelength og dCS som har produkter som jobber asynkront, også Ayre da, som lisensierer fra Wavelenght.
ceroxol
Asker
Cobra2
Det er mye villedende markedsføring ute og går...
Spesielt i "digital-verdenen" (og kabel-)
Arne K
ElvisRuler
Hva er asynkron USB? Det finnes i det minste såvidt meg bekjent ikke noe synkron USB. USB er en Universal Serial Bus.
ElvisRuler
Den artikkelen var enkel og grei, leste ingenting om synkron USB kommunikasjon?
ceroxol
Asker
Normal USB er adaptiv, hvor pc styrer.
almost all USB DACs operate in what's called adaptive USB mode, which means having to use a variable-frequency clock rather than a fixed-frequency master clock. For various reasons, a computer cannot maintain perfect timing of the data packets it sends a DAC via USB. Most adaptive USB DACs are based on one of Burr-Brown's PCM270x family of chips. The BB chip typically changes the master-clock frequency to match the average sampling frequency of the data it receives—hence the "adaptive."
The USB standards documents also list a mode of operation called "asynchronous." This is not to be confused with Asynchronous Sample Rate Converters; asynchronous USB operation is called that because the DAC's master clock isn't synchronized to any clocks within the computer. Instead, the DAC is controlled by a high-precision fixed-frequency clock, and, to match this clock, the DAC controls the flow of data packets from the computer to a buffer upstream of the D/A converter chips.
Ludo
Sandefjord
Noen av dere som har testet converteren fra M2Tech? Den ser interessant ut - vil gjerne prøve den mot det jeg har idag - prisen er jo latterlig i hifi-sammenheng...
pstraums
Flateby
Hva med Beresford Caiman ? Nå er dette gresk for meg, men dette står på hjemmesiden, når de beskriver hva den inneholder:
"PCM2902 - Adaptive Mode for Isochronous Data Transfer
Latest generation USB input with professional performance levels that finally brings USB audio into mainstream HIFI audio applications. Several times better performance compared to the level entry PCM2702 that is commonly found in a large number of USB capable Digital to Analogue Converters."
Veit ikke om asynkron og "Isochronous) er det samma jeg.. men det høres likt ut :) og denne dac`en er jo ikke så uoverkommelig priset..
Ser i ettertid at denne var litt OT, men det var mer ment som en respons til Ceroxol ang. Wavelenght og dCS
ceroxol skrev:
Cobra2 skrev:
Dette var spennende! Men jeg har nesten litt vondt for å tro at denne gjør jobben, når "hele" hifiverdenen snakker om at det kun er dCS og Wavelenght som har asynkron usb... :) Da er jo det løgn og villeldende markedsføring.
endrea
HRT Music Streamer
http://www.moon-audio.com/High_Resolution_Technologies.htm
Dette er asynkrone DAC'er som allerede har fått gode tilbakemeldinger ute i det store utland.
Jeg bruker nå selv en Music Streamer II+, og jeg kan med hånden på hjerte si at jeg har aldri før hørt bedre gjengivelse fra en digital kilde(MAC/Music Sreamer II+) her hjemme i min stue. Makan til analog lyd har jeg ikke hørt før. Borte vekk er den kalde harde digitale lyden, og endelig har jeg fått på plass den deilig og naturlig mellomtonen som jeg har manglet så altfor lenge :D og i tillegg er alt det andre som også skal være i et lydbilde på plass ;)
Det skremmende her har vært prisen. Kun $350, og så slår DAC'en knock out på det meste som jeg har hørt og eid. Jeg har liggende en Music Streamer PRO også, men denne har jeg ikke fått hørt på enda fordi jeg foreløpig mangler en mini XLR/RCA overgang. Tilbakemeldingene som jeg har fått fra de som har hørt Music Streamer PRO er at den spiller enda bedre enn Music Streamer II+. Dette er gode nyheter, men jeg kunne levd lenge og lykkelig med Music Streamer II+. Så god er den etter min mening. Den blir bedre med innspilling :)
Men det som jeg venter på er den nye HRT Music Streamer HD som skal komme rundt april. Her skal Kevin Halvorsen(Muse) lage den beste DAC'en som han er teknisk i stand til å lage. Dette uavhengig av pris. Samtidig har Kevin den filosofien at High End ikke skal koste skjorta. High End skal være tilgjengelig for alle. Kevin er blandt annet pappa'en til DVD-Audio. Det blir sagt at Music Streamer HD vil koste rundt $800 i USA.
Med bakgrunn i den utrolig gode lydkvaliten som Music Streamer II+ gir, så vil jeg ikke bli særlig overrasket hvis det er enkelte tunge produsenter av dyre drivverk som vil få store problemer med å få solgt disse etter hvert som flere og flere anerkjente hifi blader rundt om i verden tester ut produktene fra HRT. Jeg tenker da på hva som vil skje etter at Music Streamer HD er lansert.
Det får være opp til den enkelte å selv bestemme om man skal beholde sitt dyre drivverk hvis man er eier av noe slikt, men jeg vet hva jeg ville ha gjort ;), snart så vil det være vanskelig å få solgt disse driverkene til en fornuftig pris.
Den nye fremtiden innenfor digital musikk gjengivelse er rett rundt hjørnet, og til fordel for oss forbrukere vil prisen morro'a koster gå kraftig ned!
NB: Vil bare legge til at jeg har forsøkt Music Streamer II+ med både windows basert PC og MAC, og i begge tilfellene er lydkvaliteten utsøkt :D
ceroxol
Asker
Beresford har også adaptiv usb, dvs. den jobber ikke asynkront... :)
ceroxol
Asker
Da har den endelig blitt sluppet. Den er vel også første asynkrone plug-and-play løsning som støtter 24/192 (Ayre's QB-9 har også blitt levert med dette noen uker, men den benytter også Wavelenght sin Streamlenght kode..).
WaveLink HS 24/192 USB to SPDIF converter:
I know you have been expecting this release for a long time. We were waiting for OSX version 10.6.4 to be released as there were some issues with previous releases. Apple has released 10.6.4 and so we are ready to release the WaveLink product. Since Windows does not support Class 2 USB Audio we had to get a driver capable of working with our product. We therefore have the Thesycon USB Class 2 Audio driver available for our products. All of the new setup is covered in the 24/192 page.
While this will not bring legacy DACS up to the asynchronous capabilities of direct USB connectivity it will do a lot for those people wanting to connect their SPDIF dacs to computers. Since the clock in all transports are changing the SPDIF output also has to change and this is used to control the flow of audio data between a transport and dac. With the WaveLink the clock is fixed and therefore the SPDIF is fixed and this makes the receiver section of any SPDIF connected device to work really well because the internal PLL (Phase Lock Loop) that derives the Audio DATA stream connects at one frequency, locks on and stays there.
This means that the WaveLink has significantly better jitter capabilities than most transports. It also has rates available and shown with LED's for all the popular audio frequencies (44.1, 48, 88.2, 96, 176.4 and 192KHz). The WaveLink is shipped with a BNC connector for the best response and is shipped with a suitable BNC-BNC SPDIF cable and with a mating BNC->RCA adapter if your dac requires this. A high grade USB 2.0 High Speed cable is also included with each WaveLink.
$900 US Retail.
P
Parelius
Er det noen som i enkle ordelag kunne fortelle om forskjellen mellom WaveLink HS 24/192 USB to SPDIF converter og Hiface? De angår begge grensesnittet USB–S/PDIF og er begge visstnok asynkrone etter hva jeg har fått med meg. (Ingen av dem gjør DACen asynkron.)
nma
Wavelink er plug n play i OSX. (Men det er som du kan lese også utviklet en driver til Windows, som får duge til Windows en dag støtter USB Audio 2.0) Den låter også garantert bedre enn Hiface, uten at jeg har en bedre grunn enn magefølelsen for å si det. Hiface lagger vel lyden 1-2sek også? (men kan kanskje stille dette i driveren om det er tilfelle)
Det er også et pluss for wavelink at den går på interne batterier, som blir ladet automatisk når man ikke spiller av noe lyd.
CDWMcInSpots
Bergensregionen
Jeg kryssposter dette innlegget til informasjon.
CDWMcInSpots skrev:
Jaerbu skrev:
DIY_dude skrev:
Dette er et ferdig tweaket produkt. 8) Det er diskrete utgangstrinn og diskrete strømforsyninger over hele linja. Definitift forseggjort! Du får noe unikt og gjennomtenkt, mer enn hva som kan sies for 99% av dacene på markedet.
Det eneste som har holdt meg tilbake fra å kjøpe et av produktene hans er USB-receiveren. USB-løsningen er "gammeldags" og vil begrense lydkvaliteten betraktelig. Jeg ville heller kjøpt en Hiface usb->spdif converter og brukt spdif inn på dacen din.
Ja, utfra det jeg skjekket rundt på nettet skal denne være good shit.
Jeg er, som tidligere skrevet i en annen tråd, etterhvert blitt noe skeptisk til M2Tech hiFace av flere grunner:
  • Den kan ikke benytte standarddrivere, men krever egne drivere. Dette begrenser lett operativsystemstøtten og det kan lett oppstå kompatibilitetsproblemer (se neste punkt). Man er videre avhengig av et lite firmas evne og vilje til å følge opp sitt produkt over tid. Mange småfirmaer får problemer med programvareoppfølging. De neste punktene tyder dessuten på at M2Tech ikke nødvendigvis fortjener stor tillit.
  • Den hadde problemer med PCer med et eller flere AMD-brikkesett. M2Tech tok det i første omgang ikke seriøst ("det virker på vår PC") og deretter brukte de lang tid på en korrigert driver. Se i tråden "Usb 24 192khz M2tech Hiface" på Head-Fi.org (f.eks. via et googlesøk).
  • I en periode ble hiFace produsert med en annen oscillator enn i originalkonstruksjonen. Denne gav dessverre dårligere lyd. M2Techs oppfølging av saken og overfor de rammede kundene var ikke god. Se tråden "HiFace, sensitive information" på Head-Fi.org
Mulige asynkrone USB -> S/PDIF-konverteralternativer som benytter standarddrivere. Noen er fysisk større enn M2Tech hiFace.
  • Stello U3: 24 bit/192 kHz. Under test hos 6moons
  • Musical Fidelity V-Link: 24 bit/96 kHz. Har allerede fått mye ros, rimelig pris
  • Halide Design Bridge: 24 bit/96 kHz. Har fått mye ros
Tillegg:
Jeg viser til mitt innlegg i en annen tråd: "M2Tech: Et lite firma i oppstartsfasen som ikke mestrer oppgavene?".
