Har du en Mac mini så kan du nå få lyd og bilde til samme HDMI plugg inn i prosessor eller fjernsyn.
Har også USB for digital overføring.
http://www.kanexlive.com/products/item.aspx?id=3495
Design for Apple® Unibody 2009 Models. MacBook, MacBook Pro, Mac Mini, iMac
# Supports Mini DisplayPort 1.1a input, USB 2.0, Apple® Mini Jack Optical Audio Input
# Input Video Signal: Mini DisplayPort
# Input Audio Signal: Apple® Mini Jack
# Supports HDMI 165MHz/1.65Gbps per channel (4.95 Gbps all channel) bandwidth
# Supports HDMI resolution of up to 1080p
# Supports HDMI 8 bit per channel (24 bit all channel) deep color
# Supports uncompressed 5.1 channel audio such as LPCM
# Supports compressed 5.1 channel audio such as DTS Digital, Dolby Digital
# USB does not support ananlog audio signal
