Og du trodde en CD var en CD...?
mteinum
Øya
Neida... siste ut på denne fronten er:
K2 HD MASTERING GOLD CD* (COLLECTOR'S UD)
UD means the "Ultimate Disc", which is a combination of a 24K gold disc with Resonance Control Coating (RCC), directly burnt from the master disc/hard drive one at a time, then, washed by de-ionized water and finally dynamically balanced and tested and certified to be under 10 Averaged Block Error Rate (Industry standard is 220).
http://www.elusivedisc.com/prodinfo.asp?number=LIMHD028C
Du milde ::)
mteinum
Øya
Så har vi DXD:
Super High Definition format: Digital eXtreme Definition 24-bit 352.8kHz CD! Playable on all CD players!
Digital eXtreme Definition (DXD) is an audio encoding scheme that was developed for editing high-resolution recordings because DSD, the audio standard used on Super Audio CD is not ideally suited for editing. DXD is a PCM-like signal with 24-bit resolution sampled at 352.8 kHz - eight times 44.1 kHz, the sampling frequency of Red Book CD. The data rate is 11.2896 Mbit/s - four times that of DSD!
FIM/LIM DXD CDs have taken this a step further to bring you closer to the source. Instead of making two or more sample rate conversions as with SACD, FIM/LIM recorded the source in DXD! The data rate for a DXD mono signal is 8467.2MHz, or more than 3X the data rate of a typical SACD! Experience the closest you can get to the original performance in the comfort of your home!
http://www.elusivedisc.com/prodinfo.asp?number=GSDX001
Grumpy
Flott oversikt Morten.
Jeg misunner deg absolutt for samlingen din av XtractHDK2HDSSRALLYog-resten-av-alfabetet-samlingen din ;)
