benchmark tips!
Rockefoten
fra: tips om jumperne. kan gi gratis løft? skal teste i kveld og återkommer.
http://positive-feedback.com/Issue26/benchmark_dac1.htm
Addendum to Benchmark DAC1 Review
Hot Rod time!
After checking around with other Benchmark DAC owners, none report reticent or polite bass. I shouldn't either as I'm running the unit balanced bypassing the volume control. I've even changed to the Acoustic Zen Silver Reference II Balanced interconnects which cost more than the Benchmark! However, it still sounds polite on the bottom and a bit slow and fuzzy overall.
After reading the well written manual, it was obvious that the jumpers added to the output stage when using the balanced outputs were doing more than reducing the volume 20dBs. They were changing the textural cues and the bass response of the entire unit.
I popped the top, found the very small jumpers [what a pain], and moved them to the 0dB position on all four circuit board points as instructed. Dear Benchmark, the jumpers should be delivered in the zero position with the option to move them to the 10, 20, or 30 dB roll off positions if needed. You have to assume minimal smarts on the part of the person who buys a separate DAC these days.
Now we're cooking! The sound has transformed into a powerhouse of digital energy with charm and musicality galore. Using the Alesis or my Pioneer LD/CD/DVD Player, the audio approaches my super references. Moreover, the bass is room shattering with powerful, intense, focused bass going down to the center of the earth. It's now every bit as good as my venerable Theta 5a and equal to my ModWright Sony 999. Now you must make this change on the Benchmark DAC1 if you want this kind of solidity. Also, you will get added focus in the mids and highs with even more sweetness and smoothness on delicate passages. Overall, the DAC1 in 0dB mode is 10% improved in the mids and highs and 25% improved on the bottom frequencies. Its performance is just a bit behind the $3000+ DACs, with tube output stages, in textural cues. This is a gap no all solid state DAC at any price has bridged in my experience. However, the bass focus, layering, and authority is right up there now with the very best DAC brands around!
Conclusion. What a bargin! With the nefarious output jumper adjusted, the Benchmark DAC1 has evolved into a giant killer of the first magnitude. I love it. Add a top transport and quality digital cable, and my oh my it sounds marvelous. Run it balanced for best performance overall. The AES/EBU and SPDIF inputs sound about the same. The volume control works beautifully, but avoid its use for everything except headphones. Benchmark has cooked up one great DAC over the years and it's better than ever. My top buy recommendation!
Rockefoten
ser at spenningen har vært til å ta og føle på. :) vel. uansett så testa jeg dette i går og må si meg enig med mannen fra positive feedback. tok 5 min, kosta ingenting. :)
roffe
Høres jo bra ut. Hvordan låter det på de ubalanserte utgangene til sammenligning?
Rockefoten
aner ikke. har ikke kabler koblet til..
theStig
Hvis jeg leste dette riktig, så er det 20 dB demping av signalet innvendig i DAC-1 ? Fjerner man dette, så blir jo output'et temmelig "hot" for å si det mildt!
theStig
20 dB mer enn de normale 2V output blir 20 V det! Tilsvarer 50W i 8 ohm.
el_mariachi
Denne jumper-setting'n, virker den bare inn på de balanserte utgangene?
afoelges
Jumperne virker bare på de balanserte utgangene ja. Det er i tillegg en 'calibration control' (potmeter) for hver analoge kanal (virker både på bal og ubal.) som kan justeres 20dB - med andre ord totalt 50(!) dB mellom laveste og høyeste signal på den balanserte utgangen... Men hvor mange dB tilsvarer 2V peak her egentlig?
Limer inn specs for de analoge utgangene for oversiktens skyld:
Balanced Analog Outputs
Number of Balanced Analog Outputs 2
Output Connector Gold-Pin Neutrik™ male XLR
Output Impedance 60 Ω
Output Level Calibration Controls 10-turn trimmers (1 per output)
Calibration Adjustability 2 dB / turn
Output Level Range (at 0 dBFS) In Calibrated Mode +9 dBu to +29 dBu (Attenuator off)
-1 dBu to +19 dBu (Attenuator = 10 dB)
-11 dBu to +9 dBu (Attenuator = 20 dB)
-21 dBu to -1 dBu (Attenuator = 30 dB)
Output Level Range (at 0 dBFS) In Variable Mode Off to +29 dBu (Attenuator off)
Off to +19 dBu (Attenuator = 10 dB)
Off to +9 dBu (Attenuator = 20 dB)
Off to -1 dBu (Attenuator = 30 dB)
Output Level Variation with Sample Rate (44.1 kHz vs. 96 kHz) < +/- 0.006 dB
Unbalanced Analog Outputs
Output Connector RCA
Output Impedance 30 Ω
Output Level Calibration Controls Shared with Balanced Outputs
Output Level Range (at 0 dBFS) In Calibrated Mode -6 dBu to +13.5 dBu
Output Level Range (at 0 dBFS) In Variable Mode Off to +11 dBu
Factory Preset 2vRMS (8.2 dBu)
(...og hvis noen har blitt fristet så har jeg en DAC-1 til salgs, svært pent brukt...)
teo72
Høres spennende ut. Har funnet ut en annen metode å forbedre dac1 på. Den er ikke gratis, men koster deg ikke mer enn cirka 500 kroner inklusive frakt. Sølvsikringer fra Hifi-tuning i tyskland. Husk bare at du skal bestille 2 stykk 0,25A Trege sikringer. Har gjort dette selv. Man trenger ikke åpne dac1 heller. Mitt inntrykk...: Før skifte syntes jeg dac1 en slet litt med kompliserte lydbilder. Lyden ble litt uryddig. Etter skiftet forandret alt seg. Dac1 hadde plutselig total kontroll, uansett hvilken musikk jeg foret den med ... :D
Anbefales!
theStig
Whow.... +29 dBu tilsvarer ca. 21,8 V RMS. Hvor mange preamper takler dette? Det er søren meg ikke mange! Ikke rart det låter "tøffere" med en slik setting!
theStig
Ikke godt å si... men jeg savnet også substans i mellomtone og spesielt i bassen på DAC-1. Om denne modden kompenserer for dette ved å overstyre preampen er ikke godt å si....
afoelges
Jeg har testet med alt fra attenuator off til maks demping når jeg har kjørt med preampen som sitter i Benchmarken. (Balansert ut rett til poweramp) Resultatet var best uten demping - mer punch i lyden. MEN, noe særlig mer en klokka 10 var ikke tilrådelig... Hadde et par 'nær-døden' opplevelser med venner på besøk - not foolproof! :eek:
emotikon
Hvordan opplever dere brukere av denne dac`en ytterfløyene?
Rockefoten
preampen min har justerbare innganger så kanskje det hjelper? har skrudd de veldig ned.
ytterfløyeene. jeg syns den er litt avrundet faktisk. ellers liker jeg bassen. den er der bare når det er noe skikkelig dypt. veldig ekte mao
emotikon
Tror jeg må prøve en slik....
Noen i Trondheimsområdet som har?
