Resultater 1 til 13 av 13
Abonnér på denne tråden
  1. #1
    Cappuccino
    Guest
    Ditt nye tweak? Silke mellom/rundt kablene!
    Da har jeg kommet over et nytt produkt! Virker særdeles lovende!
    Fra reklamen:
    "Data demonstrates No.1 characteristic as speaker sound absorption material!
    Glass wool,wool,cotton,urethane foam and carbon paper wool is used as conventional sound absorption material.These materials did not have flat sound absorption characteristic.This is because,fibrous cell of each material was uniform.This made the particular peak and dip.
    We adopted natural silk for PSA-100.The reason is,natural silk material alone has a random fibrous cell.Natural silk has a flat sound absorption without having particular peak and dip.
    Cancellation effect on stationary wave around CD player & amplifier
    Harmful stationary wave occurs around CD player,amplifier and power supply tap.By placing small quantity of PSA-100 around equipment cancels harmful stationary wave by a distinguished diffusion effect.
    In addition,harmful static electricity occurs around power supply cable and various cable input and output terminal.With the help of natural silk of PSA-100, it removes effect of static electricity.The result is dynamic sound and improved transparency and remarkable S/N ratio."
    Kan være noe for de som virkelig som ønsker å ta den helt ut!
    http://www.acoustic-revive.com/engli...psa100_01.html
  2. #2
    Cappuccino
    Guest
    Hvem er med på Powerbuy?
  3. #3
    Mr-T
    Guest
    "Hvilken dag er det i dag...?"
  4. #4
    Æresmedlem gismo's Avatar
    Oct 2007
    Væssia i Grue.
    Tagget i
    1 Innlegg
    Album
    Er vel 1.april i dag
    Powerbuy
    gismo
    Bluesound Node 2 / Weiss DAC 202 / Einstein The Absolute Tune / Sonus faber Guarneri Memento graphite / REL Habitat 1 / REL Longbow Transmitter
    Tidal HiFi / Chord / Whistler Audio Coanda / Vertere / NorStone
    Tidal HiFi / Nuforce DDA 100 / Tannoy Revolution XT Mini
  5. #5
    Cappuccino
    Guest
    Jo, men produktet er reelt! Husker ingen han svensken som brettet spesielt papir rundt Valhalla-kablene sine da?
    Jeg har nedskalert litt og trenger ikke så mye så hvis noen ville være med å spleise ville det være fint. Blir levert kartongvis. Ikke mye fraktkostnader heller.
  6. #6
    Rubinmedlem Sluket's Avatar
    Aug 2006
    Tagget i
    15 Innlegg
    Torget
  7. #7
    Hifi Freak KW's Avatar
    Nov 2002
    Tagget i
    0 Innlegg
    ERS papir antagelig:
    http://www.enjoythemusic.com/magazin...lpointsers.htm
    Litt ned på siden der står det om det papir med innbakt ferrit.
    Mvh.KW
  8. #8
    Hifi Freak Ludo's Avatar
    Aug 2008
    Sandefjord
    Tagget i
    0 Innlegg
    EC Living Tana SL-1 & Tana L-1 / Sira L-1 Sub
  9. #9
    Servicemann RJEL's Avatar
    Apr 2004
    Tagget i
    3 Innlegg
    Garantert de som hører forskjell på dette også her inne på sentralen.....
    Det finnes 10 typer mennesker. De som forstår binært tallsystem og de som ikke gjør det!
    http://www.rj-elektronikk.no
  10. #10
    Aug 2008
    Sandefjord
    Tagget i
    0 Innlegg
    Sitat Sitat fra RJEL
    ABX fikser dette LETT
  11. #11
    Hifi Freak marsboer's Avatar
    Apr 2010
    Akershus
    Tagget i
    0 Innlegg
    Hva er rart med det der?? Jeg har da kjørt den patenten der rundt all min kabling i en årrekke.
    Bryston BDA-2 | Bryston BP-17³ | Bryston 4B SST² | PMC Twenty5.24
  12. #12
    Cappuccino
    Guest
    Sitat Sitat fra marsboer
    Hybelkaniner?
  13. #13
    Hifi Freak tweakMan's Avatar
    Feb 2002
    Tagget i
    0 Innlegg
    Er det 10 år siden jeg skrev att jeg brukte en dunpute som isolasjon under mitt drivverk? Tror det!
    1 april eller ei. Det funka som bare jølle det!!
    Så helt på viddene er jo ikke dette da..
    Forresten Belden, jupp BELDEN!!! Brukte silke som isolator helt tilbake i å ca 1900!!!
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
