Side 1 av 2 12 SisteSiste
Resultater 1 til 20 av 22
Abonnér på denne tråden
  1. #1
    Bransjeaktør Orso's Avatar
    Nov 2008
    Tagget i
    6 Innlegg
    Spennende DAC/pre fra Emotiva
    Emotiva som er kjent for å lage knakende gode produkter til prisen skal lansere en DAC med volumkontroll. Emotiva XDA-1 er navnet og prisen er antydet til 299 USD. Mulig den dukker opp i august.
    Litt info:
    Frequency response: 5-50Khz
    S/N: in excess of 110db
    THD+N: 0.02%
    Ground floor noise: 10uV
    Output voltage: 1V nominal, 12V peak
    Lonnie has also reiterated that the XDA-1 connected directly to an amplifier provides the highest quality of sonic reproduction, if that configuration works in your system.
    Has full output attenuator (volume control) - preamp could be bypassed - a remote control is to be included for this purpose
    It is 1RU (1 Rack Unit = 1.75 inches) in height
    Cosmetics are currently being updated from early test models
    Smaller black trim accessories are in the works for an all-black look
    Inputs (both)
    1) AES/EBU
    2) Coax Digital
    2) Optical Digital
    1) USB (Should be PC & Mac Compatible)
    Outputs
    1) L/R Unbalanced RCAs
    1) L/R Balanced XLRs (all outputs are hgh voltage)
    Triggers (automatic on/off for amplifiers and XDA-1 itself)
    1) 12v output trigger
    1) 12v input trigger
    Analog Devices AD1955 DAC, with 384k oversampling, and 1V rms (7V peak for extended dynamics), 24-bit, 192 kHz Sample Rate PCM Audio Data, 120 dB SNR/DNR (not muted) at 48KHz Sample Rate (A-Weighted Stereo), -110 dB THD+N (0.0003162%)
    Burr Brown buffers coming out of the DAC
    6 fully discrete output stages
    Selectable inputs
    Segmented power supply
    The XDA uses a Dual dif input stage with crosslinked current sources, Darlington VAS stage and Darlington output stages, so the speed and current it can deliver is like night and day different from the ERC. So as good as the ERC sounded (and to be honest I thought it was amazing), the XDA is in a league all its own.
    A little more detail from Lonnie regarding the quality and finesse of the XDA-1 design:
    The DAC used in the XDA is the AD1955 which is the same DAC as used in the ERC-1, But the real magic is in the analog drive stage after the DAC. In the ERC it has a single stage drive where the XDA uses a Dual Differential input stage with cross linked current sources, Darlington VAS stage and Darlington output stages. The discrete output stage can easily produce in excess of 2 amps of current and swing in excess of 12v. So it will completely take all cables out of the equation.
    http://emonatics.com/XDA-1.shtml
    Usikker om bildene under er helt representative. Det ble nemlig avgjort at det kosmetiske skulle endres noe og har gjort at den er blitt forsinket.
    Representerer lydogakustikk.no
  2. #2
    Hifi Freak pahf's Avatar
    Dec 2005
    Levanger
    Tagget i
    0 Innlegg
    Spennende, til den prisen er den helt klart verdt og prøve
    Stueoppsett: Yamaha - Hegel HD11 - Primare A34.2 - Triangle Quartet LE - Svs SB-1000
    Kjelleroppsett: Yamaha - Aune S10 - Xindak PA- M - Usher CP6311 - Klipsch SW311
    Veien er målet....?
  3. #3
    Hifi-entusiast
    Jul 2008
    Tagget i
    0 Innlegg
    Akkurat hva jeg trenger. Venter i spenning.
    Knut
  4. #4
    Hifi-entusiast ketped's Avatar
    Sep 2003
    Fredrikstad
    Tagget i
    0 Innlegg
    Så da vil en forforsterker bli overflødig?
    Er det noen som selger Emotiva i norge eller må det importeres selv?
    Onkyo 905, onkyo 3010, Klipsc RF-83 og rf-52,velodyne CHT-8Q, svs 10" Marantz KI Pearl Lite, harman kardon 670, system audio 1270. dynaudio, X-box, 2 stk PS3.
  5. #5
    Nov 2008
    Tagget i
    6 Innlegg
    Sitat Sitat fra ketped
    En aktiv forforsterker vil nesten alltid tilføre forvrengning. Så å gå rett fra kilden til effektrinn gir som oftest renere, åpnere og mer detaljert lyd. Det negative er at det kan bli for avslørende for en del anlegg.
    Emotiva selger kun rett fra egen fabrikk. Og takk for det. Ellers hadde prisen vært vesentlig høyere.
  6. #6
    Nov 2008
    Tagget i
    6 Innlegg
    Fikk e-post fra Emotiva i dag.
    XDA-1 is a couple of months out for the release. Currently there is no pricing or shipping information or specifications at this time. Please keep up to date on our website www.emotiva.com and listen also to our Emocasts.
  7. #7
    Hifi-entusiast
    Jul 2008
    Tagget i
    0 Innlegg
    Da er en XDA-1 Bestilt/reservert.
    "Emotiva will contact you about order details before your order ships (around November 30, 2010)"
    http://emotiva.com/xda1.shtm
    Knut
  8. #8
    Hifi Freak DIY_dude's Avatar
    Jan 2007
    OSLO
    Tagget i
    0 Innlegg
    Hvis den leverer 2 ampere og 12 V peak så trenger man jo nesten ikke effektforsterker engang.
    Jeg skjønner riktignok ikke poenget med et diskret buffertrinn når de allikevel bruker OPA2134 til I/V. Men prisen var ikke noe å klage på i alle fall.
    JRiver Media Center + Thuneau Allocator, exaU2I + 6 kanals ekte DIY AD1862 dac, Aspen Amplifiers NAKSA 70, Holton HPA-NXV200L R3, JBL D2 i JBL PT-F95HF, JBL 2169H i Autotech, FaitalPRO 18HP1040
    Tidligere faenjeggiropp. Har byttet tilbake til mitt opprinnelige nick.
  9. #9
    timc
    Guest
    Sitat Sitat fra Puscifer
    Knut
    Hvor mye i frakt?
  10. #10
    Hifi-entusiast
    Jul 2008
    Tagget i
    0 Innlegg
    Sitat Sitat fra timc
    Knut
    Hvor mye i frakt?
    Har ikke fått tilbakemelding om det enda. Jeg skal si i fra.
  11. #11
    Hifi-entusiast
    Jul 2008
    Tagget i
    0 Innlegg
    Sitat Sitat fra DIY_dude
    Kan du utdype disse tingene for oss som ikkke er så teknisk inne i det ?
    Knut
  12. #12
    Æresmedlem united's Avatar
    Jul 2009
    Tagget i
    1 Innlegg
    Den fjernkontrollen, kan man velge kilde med den?
    Hvis den ikke kun er for volumkontroll, er dette en meget interessant DAC for meg også.
    Vært på jakt etter en "budsjett-DAC" med fjernkontroll en stund.
    Keep the red flag flying high
  13. #13
    Hifi-entusiast
    Jul 2008
    Tagget i
    0 Innlegg
    Sitat Sitat fra united59
    Hvis du ser på bildene på siden, så ser du funksjonene på fjernkontrollen.
    http://emotiva.com/xda1.shtm#
    Knut
  14. #14
    Hifi Freak coolbiz's Avatar
    Mar 2006
    Sydvestlandet
    Tagget i
    0 Innlegg
    D/A conversion: high performance, multibit Sigma-Delta Burr Brown AD1955
    Godt gjort å få til to selvmotsigelser i én og samme setning.
    "What is important to the eye, is not necessarily important to the ear." -Siegfried Linkwitz (1935-2018 )
  15. #15
    Moderator Bjørn.H's Avatar
    Jul 2004
    Tagget i
    6 Innlegg
    Å? -forklar. -Burr Brown og Delta Sigma er vel ikke heeelt det samme..?
    Hegel H90, Monitor Audio GS20, Gold C150, Reloop Turn5 m/Clearaudio Virtuoso, Rega Fono MM, Bluesound Vault2, Chromecast, Blue Jean Cable, Yamaha RX-V3800, Sony BDP-S5500. Selges: Focal/JM-Lab: Chorus 736S, Chorus CC700S, Chorus SW700S, Chorus 706S m/org. stat.
  16. #16
    Mar 2006
    Sydvestlandet
    Tagget i
    0 Innlegg
    Sitat Sitat fra bjornh
    1) multibit er ikke heeelt det samme som Sigma-Delta. (det er det "motsatte")
    2) Burr Brown er ikke heeelt det samme som Analog Devices.
  17. #17
    Jul 2004
    Tagget i
    6 Innlegg
  18. #18
    Jul 2009
    Tagget i
    1 Innlegg
    Knut
    Takk, den kontrollen så veldig fin ut.
    Da er det selve lydkvaliteten på DAC'n det står på.
    Så ut som om den kunne levere 230V iallefall.
  19. #19
    Parelius
    Guest
    Noen som har den i hus nå?
  20. #20
    Æresmedlem motoren's Avatar
    Jan 2007
    Flekkefjord
    Tagget i
    12 Innlegg
    Torget
    Sitat Sitat fra Parelius
    fikk mail fra Emotiva om at den ikke kan leveres før slutten av februar
    JMLab Electra 920.1<br />Audio Research LS 3 pre<br />Monarchy Audio NM 24 tube DAC<br />Denon DCD 1650AR<br />biamper med Pass F5 Power amp/Hypex UCD 180<br //Clearaudio Concept/Mcru power supply/LM Audio LP33 Tube riaa/ Audio Technica 33EV <br /Tributaries serie 8 speaker cables>/Audioquest K2 Ht cables<br />In.Akustik Reference digital<br />In-Akustik Reference ic<br />Marantz DV 8003 Multispiller/ Nos Mullard
Skrive Tillatelser
Om Hifisentralen
Følg oss på sosiale medier:
Facebook Twitter RSS Feed
