Tact Dynamic Room Correction?
HåkonN
Noen som har erfaring med Tact DRC?
http://www.tactlab.com/DRC/how_DRC_works.html
Tact DRC ser ut til å korrigere i frekvens og tidsdomenet, og har mulighet for target-kurver. Men den har også en etter min mening en veldig spennende funksjon jeg har savnet i andre korreksjonsløsninger.
Tact DRC systems are the only ones in the world to address the issue that sound perception is both frequency and level dependent. (Fletcher-Munson Curves) What this means is that as you change the level of your music, your perceptions of certain frequencies will get skewed - you will perceive certain frequencies as either louder or softer. The natural tonal balance of your music will be lost.
DRC is the only technology in the world that preserves natural tonal balances by dynamically adjusting your entire system in accordance to the human hearing characteristics, your hearing characteristics. By using your relative loudness perception, equal loudness curves,Tact DRC connects your sensory perceptions directly into your system. It then, for every 0.1 db level change, dynamically recalibrates your system based upon your unique loudness perceptions and full-spectrum room correction. The future of audio is here.
Tact ser også ut til å komme med en avansert 12-kanals prosessor med denne korreksjonen på alle kanaler, og som også inneholder delefilter som gjør (etter som jeg skjønner) at den kan brukes i en løsning med aktive høyttalere. Ser ut som den har samme DRC som RCS 2.2 XP (og som noen her kanskje har erfaring med?).
• Support for all major decoding algorithms including HDMI support
• Support for simultaneous processing of eight analog or eight digital input channels
• Twelve output channels. Each output can be configured as main or subwoofer channel
• Dynamic Room Correction on all twelve outputs
• Subwoofer Diversity Correction can be applied to selected subwoofer channels
• Variable frequency correction
• Measurement and target curve normalization
• Crossover filter design
• On-the-fly adjustments of all correction parameters on all twelve channels
• Eight channel mixer on each output
• Twelve channel time alignment and level balancing
• Complete system verification on all twelve channels
• Impulse response screen
• Fully supported by Tact-V1.0 software platform
• Extensive RS232 control codes.
• 8 digital inputs - six SPDIF, one AES/EBU and one optical
• 5 stereo analog inputs - four single ended (RCA) and one balanced (XLR)
• 4 HDMI inputs and one output
• 6 digital outputs - six SPDIF and six AES/EBU
• 12 analog outputs - twelve single ended (RCA) and twelve balanced (XLR)
• Microphone input
• One 12V trigger output
• Two RS232 ports - one for PC connection and one for amplifier control
ragwo
Mud-fi freak
Bodø
Har dessverre ingen erfaring med DRC men det virker veldig interessant!
