bambadoo skrev:
Har du noe budsjett for dette?
Er den Music angel forsterkeren din en integrert sak? Og evt. hva er inngangsimpedans?
Dene er integrert, litt usikker på inngangsimpedansen. Music Angel XD845 King 845 Stereo Vaccum Tube Integrated Amplifier.
Har litt infor her:
# Input Power : 240V AVAILABLE (110v MAY NEED 1 - 2 WEEKS FOR Order)
# Power : 20 watts RMS x 2
# Output Tube : 845x 2 Adopts classic parallel single terminal circuit
# Input/Driver Tube : 6N8P/6SL7 x 2, 6N9P/6SN7 x 2
# Adopts US AB carbon core resistances
# West Germany wimA coupling capacitance ALPS potentiometer
# Hitachi Qirui oxygen free copper enameled wire and one-way audio frequency silicon steel sheet etc
# Ohms : High-Voltage time-delay power supply 4 ohms and 8 ohms
# Frequency :10Hz-40KHz +/-3 dB
# Signal/Noise Ratio : 90dB "Hi END Outstanding Signal/Noise Ratio"
# Distortion :Less than 1% at full power
# Input Consumption : 200w
# Weight :28kg
# Size Dimension : Width 465mm, Height 175mm, Depth 280mm
# Colour : Silver Body & Black Power Supply
# All data is based on Manufactory figure. Subject to change without notice Music Angel
