mteinum
Noe dyr, men konseptet var ikke dumt:
Ear Pressure Equalizer
http://www.proidee.co.uk/shop/SID_B...0438/K=02_GB_120057/HI=produktuebersicht_bild
The Ear Pressure Equalizer sucks air from the outer ear canal creating a slight vacuum which gently pushes the eardrum back into its original position.
Andrew Liszewski skrev:Im a rather easy-going and patient kind of guy, but if theres one thing that can instantly drive me to Incredible Hulk-like levels of rage is when my ears dont pop after Ive gotten off a plane. Normally the suggested yawning or swallowing is enough to solve the problem, but every once in a while theres just nothing that works and I have no choice but to just wait it out and try and control the beast inside me. Until now that is.
This ear pressure equalizing device is basically nothing more than a small pump that creates a vacuum in the outer ear canal that gently pushes the eardrum back into its original position. You just stick the tube in your ear, push the yellow membrane and youre done. Of course theres always a safety concern with any device youre supposed to stick in your ear canal, but the Ear Pressure Equalizer features a safety vent that prevents the build-up of too much pressure. And if you still dont think its safe, keep in mind it was developed by Professor Burkhard Franz, founder of the renowned Tinnitus Research and Balance Clinic in Melbourne Australia. If you cant trust a professor, who can you trust? The whole thing packs up into a package thats smaller than most mobile phones and can be yours from Pro-Idee for an inexplicably expensive $60+.
