«Many of the variations in recordings take forms that can be addressed by old-fashioned bass and treble tone controls. Unfortunately, tone controls are frowned upon by audio purists, who think that they somehow degrade the performance. As a result not all equipment has them, and the ability to compensate for quite common and simple variations like too much or too little bass is lost. The notion that recordings are inherently flawless is seriously misguided, as is the notion that a “perfect” loudspeaker will sound good with all recordings. We need to be more realistic, acknowledging that “loudspeaker” music is not the same as live music. There are fundamental similarities to be sure, but there are also gross differences. No magic wire, loudspeaker stand or spike, power line filter or trinket on a wall will make it right».Tilbake til tweaking, tester ut en semi-organisk kurvetrend. Leker forsiktig med tonekontrollen mao.
Jeg vet at for en tilfeldig besøkende eller for den jevne HFSer betyr dette null og nix og de fleste gir egentlig beng. Men for meg som sitter timesvis og lytter på dette jangelet, betyr det mye. Vil påstå dette kan sammenlignes med tuberolling, bytting av PU eller andre slike hørbare tweaks og utskiftninger, som den mer tradisjonelle audiofile synes er morsomt.
Toole
