Merlin BAM?
Hei, hva kan dere si om denne? bass-alignment module. Regner med det er en EQ for bass.
Evt. finnes det noen andre "oppskrifter" på nett på tilsvarende? Evt. kits og slikt. Ser den er batteridrevet.
123petter
BAM i forskjellige utgaver er en modul beregnet for bruk med Merlins høyttarere. Ikke noe Kit eller noe som er beregnet for andre merker. BAM er en integreert del av Merlins høyttalere, fungerer emm absolutt helt strålende:
Bass Optimization Technology: The Merlin BAM improves the already impressive bass capabilities of the VSM loudspeaker, adding new levels of low-end weight and depth. The BAM effectively extends the low-frequency response of the VSM in a phase and amplitude correct manner to –4 dB at 30Hz with no alteration to the rest of the speaker’s exceptionally flat frequency response or musical characteristics. The BAM has the same exceptional internal parts found in the VSMs themselves, further ensuring that the qualities of the VSM will not be harmed in any way. It also includes a battery based power supply, which removes the last vestiges of any electronic signature from the BAM’s performance. The BAM is easily inserted in the signal path between preamp and power amp or in any suitable tape loop.
Videre:
http://www.merlinmusic.com/vsm_bam.htm
Emm: En sensajonelt bra høyttaler, har selv MXR versjon og (straks) Master BAM/RC.
Joda vet det, men prinsippet er det jeg tenker på.
Takk for link foresten.
BAM does this by applying a carefully contoured boost (5.2dB) centered on 35Hz in conjunction with a built in subsonic filter below 28 Hz.
THE S-BAM
The S-BAM is battery-powered and includes a self-contained rechargeable battery system. The battery S-BAM allows you to operate the unit in AC or battery modes. In the battery mode, the last vestiges of AC related noises are removed to allow the speaker system to exhibit its maximum resolution. Fully charged batteries will allow the S-BAM to operate for up to 10 hours in full battery operation.
S-BAM CONNECTION & OPERATION
The S-BAM is a line level component and should be connected with high quality interconnects. We recommended that the S-BAM be connected between your source and the preamp's appropriate line level input. If you use multiple sources, you should use the S-BAM in a tape loop, this will also, allow you switch it in and out of the signal path for comparative purposes. Due to the buffering provided by your preamp's line output stage, you may find that the sound is "juicier" when connected between your source and preamp or in a tape loop. If the afore mentioned set-ups are not an option, connecting the S-BAM between your preamp and power amplifier will still give you better performance than not using it at all. Experiment for yourself and choose the setup you prefer.
Integrated amplifier based systems require that the S-BAM be connected into a tape loop when multiple sources are used. If there is only one line level source, the S-BAM can be connected between the source and the integrated amp. Plug the S-BAM into a wall socket or line conditioner.
Ok - så det ser ut for at det er en "line level eq". "Evt. line level baffle step"
http://sound.westhost.com/bafflestep.htm
N
nb
Det fremstår for meg som noget merkelig å betale i sikkert ganske dyre dommer for en ikke-innstillbar EQ for å fikse på bassen til en bestemt høyttaler. Det må da være bedre å gjøre dette med utstyr hvor man faktisk kan tilpasse den til egne ønsker og eget lytterom når man først er i gang med EQ der nede?
Eller er det noe jeg har misforstått med BAM?
123petter
Ja, det er det.
BAM er en integrert del av denne høyttaleren og kan nok ikke erstattes av tilsvarende produkter levert av andre produsenter. Bare BAM er BAM hvis du skjønner hva jeg mener, uten at også dette behøver å bli en lang tråd om hva som er bra, fornuftig etc etc. Vi som har Merlin vet at dette fungerer og det fungerer som en kule. Det holder, ihvertfall for meg.
Hei - ja det er bra. Saken var å evt. lage en tilsvarende løsning. (selvsagt ikke identisk) men funksjonsmessig lik for evt. andre prosjekt? Dvs. tilpasse "teknologien/løsningen" til et annet prosjekt.
Så det var derfor spørsmålet kom opp. En "BAM" for Merlin vil naturligvis ikke fungere for andre på samme måte.
N
nb
Løsningen finnes vel allerede og heter EQ. BAM er muligens gjort med komponenter, EQ som er veldig innstillbar er gjerne digital nå for tiden. Så en replika-BAM ville da vel være en sak som gjør den nødvendige frekvensmanipulasjonen med et passende utvalg komponenter?
123petter
Sikkert en spennende idè, lykke til.
LMC
Drøbak
men BAM påvirker selvfølgelig lasten som pålegges forsterkeren
"additiv" eq krever mere effekt
"there´s nothing like a free lunch!"
Leif
Audiomix
Gratis lunsj er noen ganger oppskrytt ;D
Som det skrives her oppe gir en BAM løft i bassen. Det vil si at forsterkeren som driver høyttaleren enten må ha tilsvarende mer å gå på eller den gir opp tidligere.
Jeg kjenner ingen som har opplevd dette som et problem, men lurt å huske på.
En BAM vil gi samme korreksjon enten den brukes sammen med Merlin eller andre høyttalere.
Den sitter tross alt mellom for- og utgangsforsterker.
D
Dilla
Det sitter vel på sett og vis en "BAM" i DP's siste forforsterker, er det C1 den heter? Mener denne kan heve nivået i et par trinn i 3 forskjellige frekvensområder (30, 60 og 120 Hz?). Kanskje Ernstsen vil fortelle litt om hvordan dette er gjort i denne forsterkeren?
Nightpuma
Agder
Jeg vet at David Berning har laga en "tube BAM" til Merlin. Kanskje han kan dele noen ideer med seg. Ellers mener jeg Merlins Bam er opamp basert. Den kutter så vidt jeg vet også ut alt under 30Hz
http://www.davidberning.com/
Puma
thomaslmh
Hei, jeg har en integrert forsterker, men bruker både platespiller og streamer. Hvordan kobler jeg BAM da for å utnytte den for begge kilder? Har lest at den kan kobles i en tape loop, altså tape out - BAM - tape in, men hvordan har det noen betydning ettersom de to kildene må kobles til to andre innganger (feks. CD og Phono)?
Fenalaar
Du kobler BAM i tape monitor-sløyfa. Så setter du record select til den kilden du vil bruke.
Johan-Kr
thomaslmh
Tusen takk for svar. Jeg har kun en bryter i front det står REC out på. Antar jeg vrir den til "on" og at resten skjer automatisk?
jakr
Jeg hadde et par Merlin høyttalere med Master Bam. Jeg kjørte disse i fjor sommer uten bam og istedenfor med to subber som var innstilt i henhold til den økningen BAM gir ved ulike frekvenser. For å si det enkelt, jeg kjørte ikke Merlin med bam etter at jeg fant ut hvordan subbene måtte stilles. Mer av alt til et par fantastiske høyttalere..
JAKr
thomaslmh
...neste spørsmål: er det mulighet for å koble bam mellom pre out og Main in på integrerte forsterkere?
thomaslmh
Bytte av batterier i BAM
Hei igjen, godtfolk. Jeg mistenkte at minst ett av batteriene ikke lot seg lade, åpnet BAM'en og fant at ett batteri ikke lader. De andre målte jeg ujevne verdier med et voltmeter. Så er spørsmålet: Det sitter i 4 stk 9,6 V 230 mAh av denne typen:
https://www.amazon.com/Powerex-MHR9V-230mAh-Rechargeable-Battery/dp/B0002LAKOS
Disse er ikke å oppdrive i Norge. Løper jeg noen risiko ved å kjøpe fire nye 9 V 200 mAh?
Feks: https://www.kjell.com/no/produkter/...r/varta-oppladbart-9-v-batteri-200-mah-p42710
roadrune
Stord
Det er vanligvis samme celletype i slike batterier (nimh eller nicd) der cellespenningen er gitt av celletype og ikke produsent uavhengig av reklamen.
Den største forskjellen i spenning ligger mellom oppladbare (nimh og nicd) kontra engangsbatterier, det engangs har litt høyere spenning, men på den andre siden mindre strøm (mAh)
Med andre ord; du vil få litt lavere driftstid, og hvis den har høye strømtopper kan den droppe litt der. (Kjenner ikke produktet, aner ikke hva det er :p )
