Hej..
Jeg har lige et par små spørgsmål.
Håber nogen har nogle erfaringer og indput de kan / vil dele...??
Undskyld det er på engelsk men jeg har lige klippet det ind fra et engelsk sproget forum jeg også deltager i..
Håber det er til at forstå alligevel?
Hey...
Dos anybody here have any experience with the combination of : ScanSpeak D2905/9700 and Audiotechnology (Skaaning) C-Quenze 18H52-17-06 SD. ?
X over type, best cross over frq. and best filter order?..
Dos anybody have any good solutions?
Also in combination with an 12" Peerless bas? (315SWR) in 120 liter closed box.
The 18H. driver will work in a 14 liter closed box.
Right now i cross over at 190 Hz. (2½ vay) and the 18H have full baffl compensation and therfore a sensetivity at around 86 - 87 db.
I use at 2 order at 2,2 Khz. between tweater (9700) and mid. there right now is an ScanSpeak 18W/8546-00, (but this will soon be replaced with the 18H C-quenze) that works fine..
BUT!
I would like til cross a little higer and get alittle more sensetivity and less baffl comp. for "mid" (18H)
Anybody got an idea??
mvh.
