Data på Acousto-pro PA-1250 8ohm
Jan_I
Er det noen som har eller vet om dataene på et 12" Acousto-pro PA-1250 8ohm basselement?
Alle opplysninger tas i mot med stor takk
Mvh Jan I
el_mariachi
Kan det være et av disse to?
Acousto Pro P-1250
Data from http://www.thielesmall.com
Brand Acousto Pro
Model P-1250
Description
Range / type Bass
Typical use HiFi
Recomended enclosure
Series
Manufacturer
Order nr
Production status active 2003
Nom. diamerer [inch] 12
Vas [Liters] 106
Qts 0,67
Qes 0,71
Qms 11,5
Fs [Hz] 48
Sensitivity [dB] 99
Max Power [W] 100
Power definition RMS
Lower freq [Hz]
Upper freq [Hz] 4500
Rec. Filter freq [Hz]
xmax [mm]
Moving mass [g]
Disp area [m2] 0,0511
Disp Vol [cm3]
xdamage [mm]
Air gap [mm]
Coil height [mm]
Coil diameter [mm]
Cms [mm/N]
Rms [N*s/m]
Magnet weight [gr]
Magnet height [mm]
Magnet diameter [mm]
Magnet material -
Re [ohm] 7,2
Z [ohm]
L [mH] 1
Bl [Tm]
Magnetic flux [Wb]
Flux density [T]
Outer diam. [mm] 307
Bolt circle [mm]
Nr of bolts [Nr]
Cutout [mm] 282
Weight [Kg]
Height [mm]
Depth [mm]
Driver volume [Liters]
Frequency SPL / Z
Home page [url]http://www.starfelt.se/
Data sheet [URL}
Enterd by -
Date reviewed 2003-10-23
Date added 2003-10-23
For more information, see the manufacturers web page or your local distributor.
Acousto Pro P-1250A
Brand Acousto Pro
Model P-1250A
Description
Range / type Bass
Typical use HiFi
Series
Manufacturer
Order nr
Vas [Liters] 80
Qts 0,75
Qes 0,81
Qms 11,1
Fs [Hz] 56
Sensitivity [dB] 101
Max Power [W] 100
Lower freq [Hz]
Upper freq [Hz] 5000
xmax [mm]
Moving mass [g]
Disp Vol [cm3]
xdamage [mm]
Air gap [mm]
Coil height [mm]
Coil diameter [mm]
Cms [mm/N]
Rms [N*s/m]
Magnet weight [gr]
Magnet height [mm]
Magnet material -
Re [ohm] 7,1
Z [ohm]
L [mH] 1,3
Bl [Tm]
Magnetic flux [Wb]
Flux density [T]
Outer diam. [mm] 314
Bolt circle [mm]
Nr of bolts [Nr]
Cutout [mm] 282
Weight [Kg]
Height [mm]
Depth [mm]
Frequency SPL / Z
Jan_I
Takker for dem el_m
har funnet disse, men er i tvil om det er noen av disse.
ser at max power ikke er lik det som står på baksiden av elementet
Mvh Jan I
Vidar Øierås
Ser ut til at det er øverste forslag som er dine elementer. Ser de har høy Qts. Tror du kan eksperimentere med åpen baffel på disse. Du får ikke dyp bass uansett med disse uten aktive tiltak, men jeg tror du kan få bra og linjær bass ned til 50Hz i åpen baffel.
Mvh.
Vidar
