Ta kontakt for demo (mkII) og tilbud
moetaudio.com
the-ear.net
A200S fits nicely into any Hi-Fi setup, offering one XLR and five RCA inputs, a single pair of speaker terminals and also a pre-output for use with a separate power amplifier or active speakers. A200S can be also used in special by-pass mode as a pure power amplifier. All easily controlled from comfort of your couch with our classic YBA remote controller.
As with all YBA products, the chassis rests on three feet. Two of which are damped and the third one with special aluminium construction, serving as a vanishing point of vibrations.
We improved the digital section of the A200S, upgrading its DAC to the AKM AK4493EQ chipset, which offers a native support of High-Resolution files all the way to PCM 32bit / 768 kHz and DSD512. Just connect it over USB to a computer and start enjoying your music in its full potential.
If you prefer simpler and wire free setup, A200S can be connected directly to your smartphone or tablet over its Bluetooth 5.0 input. A200S even supports advanced LDAC and aptX HD Bluetooth codecs for a Hi-Fi quality wireless playback.
For use with a separate DAC or CD player, the whole digital section of A200S can be quickly disabled, resulting in an improved performance of its analog circuit.
SPESIFIKASJONER
YBA HERITAGE A200
Lyd opplevelse høyttalere forsterker avspiller radio blåtann bluetooth dac d/a konverter kabel signal rack stativ platerspiller vinyl Lp
YBA Heritage A200 | The Ear
One of my very first reviews for the Ear, almost a year ago, was of the YBA Passion IA350 integrated amplifier and the matching CD430 disc player. I
SPESIFIKASJONER
Product type | Integrated Amplifier |
Audio outputs | 1 Pair Speaker Outputs 1 Pre‐out (RCA) |
Power output | 110W into 8Ω 165W into 4Ω |
SNR | >95Db |
Frequency Response | 20 Hz – 20 kHz (–0.5Db) |
THD+N | <0.04% (20 Hz – 20 kHz) |
D/A CONVERTER | AKM AK4493EQ |
USB Input | XMOS XU208 – PCM 32bit / 768 kHz & DSD512 |
Bluetooth Input | Qualcomm CSR8675 BT5.0 LDAC, aptX, aptX HD, AAC, SBC |
Audio Inputs | 1 Balanced XLR, 5 RCA & 1 Digital Optical |
Power Supply | Linear power supply with high performance transformer 330VA |
Color / Finish | Natural aluminium |
Dimensions (w x d x h) | 430mm x 400mm x 118mm |
Weight | 10 kg |
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
