Ta kontakt for demo og tilbud
moetaudio.com
www.hifichoice.com
Review: Yba Genesis Ia3a Integrated Amplifier - StereoNET
The addition of Bluetooth to the Genesis range of products added a level of excitement to the legendary YBA hi-fi brand. Without too much trouble, a user can simply pair with whatever device may be preferred (phone, tablet etc.) and be listening to music in no time at all!
The preamplifier offers so much more however …. the IA3A is equipped with one S/PDIF (75 ) COAXIAL digital input, USB (24/192KHz) as well as Bluetooth to receive digital signals from separate digital components. All digital inputs automatically adjust to any of the standard digital-audio datarates from 16/44.1 KHz to 24/192 KHz. There is one digital output plus a pre-out option to use a subwoofer, a separate power amplifier or active speakers.
The preamplifier allows the connection of 2 RCA input sources, where the video input has a bypass option. There is also a balanced input. Should you wish, you can disconnect power to the digital section of your IA3A when using an analogue source. Remember to re-engage this switch when using any digital inpu
YBA Genesis IA3A
Lyd opplevelse høyttalere forsterker avspiller radio blåtann bluetooth dac d/a konverter kabel signal rack stativ platerspiller vinyl Lp
YBA Genesis IA3A
"Darling, it’s a life of surprises”, or so sang Prefab Sprout singer/songwriter Paddy McaLoon. He’s right you know, and hi-fi never fails to cause one’s eyebrows to twitch. Just when you think things are going stale, along comes an interesting new brand and suddenly things change – just a...
Product type | Integrated Amplifier |
Audio outputs | 1 pair of speaker outputs, 1 pre-out (RCA) |
Power output | 105W @ 8 Ω per channel 150W @ 4 Ω per channel |
Gain | +6dB |
SNR | > 95dB |
Frequency Response | 20Hz-20kHz (-0.5dB) |
THD+N | < 0.03% |
Inputs | Coaxial, USB, Bluetooth 2 RCA analog signal inputs 1 Balanced analog signal input |
DAC | Cirrus Logic CS4398 |
Power Supply | Linear power supply with high performance UICore transformer 300VA |
Color / Finish | Black aluminium with black acrylic panel |
Dimensions (w x d x h) | 430 x 404 x 115 mm |
Weight | 12 kg |
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
