Kraftig vellydende effektforsterker selges grunnet overgang til integrert.
Fått gode omtaler: https://audiophile.no/nb-no/omtaler/effektforsterkere/item/1820-usher-r-1-5
Spec:
8 Ohm: 150W(ch)
4 Ohm: 260W(ch)
damping factor: >175 (single ended)
circumgyration: >40V / uS
power supply (4 Ohm): >16A
transient power supply: >75A
S/N ratio: 100 dB
frequency (20Hz-20kHz): - 0.25dB
(20Hz-100kHz): - 3dB
weight: 37 kgs
dimension (w x d x h ): 48 cm x 48 cm x 22.5
Pris kan diskuteres ved hurtig avgjørelse.
Spec:
8 Ohm: 150W(ch)
4 Ohm: 260W(ch)
S/N ratio: 100 dB
weight: 37 kgs
- Originalemballasje
- Ja
- Orig. kvittering
- Nei
- Forsendelse
- Må hentes
