Stello S100mk2 veil pris 10500,-, restlager selges nå for 6300,-
...Musikk gjengis nøytralt og ufarget nærmest uansett nivå og kompleksitet. Med disse Stello komponentene har April Music befestet sitt rykte som en usedvanlig kvalitetsbevisst leverandør med et tydelig lydideal.Anders Rossnes www.audiofidelity.no.
Designed for entry into high-end audio reproduction, the new stello performs several levels higher than the intended pricing. Bridging the gap between HiFi and Audiophile, the MKII shows the hidden depth of music.The stello HP100 / S100 Series is the answer to your passion, the advanced reproduction of sound. Pure & Simple
These are the intended purpose of stello HP100 MKII. Focusing on the fundamentals, the MKII produces high-end performance sound at sensible price. Powerful Toroidal transformer
The stello HP/100 Headphone / Preamp utilizes exclusively designed toroidal transformer, assuring stable input-voltage for strong dynamics and subtle nuances of music. And, in order to maximize the design potential, the balanced input connectors are employed, further lowering the noise level. Beauty of Iron
Alex Rasmussen, the principle architect of the EXIMIS chassis, continues the unique design concept of April Music in the stello 100 MKII series. Pure A class amplifier
The stello HP100 MkII is equipped with pure class A, Push-Pull output circuitry. The J-FET - Low Noise transistor is applied to the input section of the preamp.
The Bipolar transistor scheme is used in the headphone output and it provides exceptional sound and dynamic drive. The input impedance ranges up to 1 mega Ohms and can be connected to all types of interconnect cables, providing very stable operation. Apart from the DC Servo Control circuit in the headphone amp section, the entire preamp board is designed with discrete circuitry for fine tuning and elevated sound quality.
Test 6MOONS
Tekniske data
POWER OUTPUT 2 X 50 watt 8ohm
Test 6MOONS
Tekniske data
LINE INPUTS | 1 pair of unbalanced input 1 pair of balanced input |
INPUT IMPEDANCE | 68 kOhms |
SPEAKER OUTPUT | 1 pair |
FREQUENCY RESPONSE | 10 Hz ~ 45 kHz |
SIGNAL TO NOISE | 10 Hz ~ 20 kHz, -100 dB THD+N : 0.002%, at 10 Watts |
POWER TRANSFORMER | specially built toroidal |
DIMENSIONS | 8.6 × 2.12 × 11 inch (WHD), 219 × 54 × 296 mm (WHD) |
WEIGHT (NET) | 8.82 lb, 4.37 Kg |
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
