Hifi&Vinyl
Butikk SME 3012 Series I
Platespiller tilbehør
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Akershus
Pris
Kr 17.000
Annonse beskrivelse
Annonse nummer: 253686
Til salgs er en svært sjelden versjon av denne ikoniske armen.
Denne tidlige versjonen ble produsert så tidlig som 1958-1962 i ett begrenset opplag.
Interwebben er full av informasjon om denne armen.
Her er noen nøkkelpunkter, hentet fra nettet, som forklarer noe av forskjellene på denne og senere versjoner :
You will notice some incredible differences in this arm compared to any other SME 3009 or 3012.
1st these extremely early Series I arms had no serial numbers. They were only stamped on the bottom “Made In Englandâ€
2nd notice at thickness of the base plate & boss Both pieces are at least three times thicker than on any subsequent arm.
3rd please notice the cueing mechanism and cueing lever. Completely different than on any other subsequent arm.
4th check out the rear main weight assembly and out rigger weight. These combine for an unheard of total weight of 360 grams. Definitely not made for any 7 gram cartridges. To balance a heavy Ortofon cartridge the main counter weight must be slide almost completely forward.
5th notice the Acorn nuts. They have no slots cut into the top side. When was the last time you saw Acorn nuts with no slots in the top. Answer “neverâ€
6th please take special note of the knife edge bearing. You will not see this shape of knife edge bearing use in any other SME arm
7th the anti-skate assembly is nothing more than a small add on
Forsendelse
Kan sendes
Hifi&Vinyl
Torget karakterer
Vurderinger (17)
Andre annonser av Hifi&Vinyl
