Selger en strøken Rothwell stepup .Under ett år gammel. Den er helt støyfri og trenger ikke strøm, bortsett fra signalet fra platespilleren. Importerte denne fra England, og betalte vel ca 4500.- selges for 2200.- inkl porto.
The MCL uses transformers supplied by Lundahl of Sweden and is a superb step-up transformer designed specifically for modern low output moving coil cartridges and optimised for use into moving magnet phonostage inputs. It features very wide bandwidth, low distortion and carefully designed primary and secondary loading networks to optimise the performance and give beautifully reproduced transients, free from ringing. The core materials and winding techniques employed in the manufacture are unsurpassed and feature multiple primary and secondary windings configured to cancel hum pickup from external sources as well as minimise inter-winding capacitance and maximise bandwidth. The step-up ratio makes it compatible with a wide range of cartridges and our proprietary loading networks maintain a 100 ohm input impedance, also compatible with a wide range of cartridges.
Helst PM, ev SMS til 47753659 ( ikke bland PM og SMS, blir fort litt feil
http://www.rothwellaudioproducts.co....ansformer.html
