Moet Audio
Butikk Revival Sprint 4 - demo i Stavanger
Gulvhøyttalere
Selges
Tilstand
Ny
Utløpsdato
Fylke/land
Rogaland
Pris
Kr 24.990
Annonse beskrivelse
Annonse nummer: 248877
Spennende høyttaler ifra Revival i budsjettklassen. Kan høres i butikken i Stavanger.
hifitest.de 5 av 5 stjerner
Visually elegant, technically a treat and a wonderful sound: The Sprint 4 is the next big thing from Revival Audio.
Revival Audio Sprint 4 - Stereo Speakers Review - very good (hifitest.de)
SPRINT 4 - Punches Above Its Weight! | Revival Audio
Punches Above Its Weight!!
Say Hello to SPRINT!
Reimagining What A Speaker Can Do
SPRINT is so much more than an affordable speaker range. Based on almost four decades of expertise, SPRINT is the brainchild of some of the most innovative minds in the industry. We are amped to be bringing SPRINT onto the scene, reflecting our brand philosophy of taking listening to the next level.
Designed and engineered in the heart of France, at the award-winning Parisian A+A Cooren Design Studio, SPRINT boldly punches above its weight by doing so much more than any speaker you’ve seen before.
It’s just as beautiful as it is functional, slipping seamlessly into any living space or entertainment area. And beneath the surface, you’ll find the same cutting-edge acoustic tech and unbeatable sound that powered our immensely successful ATALANTE line. SPRINT is the next generation in the REVIVAL AUDIO family, carrying on the legacy in style.
KEY FEATURES
SPRINT’ing Miles Ahead! A 100% Original Innovation
SPRINT 4, the 2.5-way floorstander inherits the ATALANTE line technologies.
SPRINT proudly inherits the same technology that powers our ATALANTE line, with a twist that makes it uniquely SPRINT. It features a 28mm RASC soft-dome tweeter and built-in ARID (Anti-Reflection Inner Dome) patented technology. With its specialised back-chamber design, this stylish speaker design is capable of absorbing over 95% of unwanted resonance within any space to elevate your listening experience, whether you’re reminiscing over your vintage vinyls or playing your favourite new playlists of the 21st century.
SPRINT also features two the high-end BSC (Basalt Sandwich Construction) 7” woofers, perfectly balancing out rigidity and lightweight design. With superior damping construction, SPRINT promises a rapid yet smooth response with impressively tight bass dynamics.
The ELYTRON front baffle is an original Revival Audio creation; a stylish speaker design developed through hundreds of hours of painstaking simulation. Such listening precision has never been seen before at its level, and won’t be seen again soon from any other manufacturer, unless they copy SPRINT. But that’s ok, because that’s our goal: To create new trends and technology in the speaker industry, with sound precision that must be heard to be believed.
TECHNICAL SPECIFICATIONS
Type2.5-way floorstanding loudspeaker
Drivers
  • 1 1/8” (28mm) soft-dome tweeter equipped with Revival Audio ARID (Anti Reflection Inner Dome) patented technology with a large back chamber with a low resonance frequency of 650Hz
  • 7” Mid/bass (18cm) BSC (Basalt Sandwich Construction) woofer
  • 7” Bass (18cm) BSC (Basalt Sandwich Construction) woofer
Frequency Response (+/-3db)45Hz – 22kHz (-3dB)
Sensitivity (2.83V/1m)89dB/2.83V/ 1 metre
Nominal Impedance4 ohms
Minimum Impedance3.8 ohms at 200Hz
Crossover Frequency1.6kHz and 2.2kHz
Recommended Amplifier PowerPower handling: 180 watts, starting from 30-50 watts.
Recommended Room Size30 to 60 m2
Dimensions (H*W*D)1060 mm x 213 mm x 307 mm
Net Weight20.6 kg (45.42 lbs.)
Originalemballasje
Ja
Orig. kvittering
Ja
Forsendelse
Kan sendes
Moet Audio
Torget karakterer
Vurderinger
Andre annonser av Moet Audio
