Brakdeby for Revival med denne stativhøyttaleren som har fått strålende tester. A high End Bargain ifølge ear. I demo hos Moet Audio i Stavanger
ear
Revival Atalante 3: A High End Bargain | The Ear (the-ear.net)
What HIFI
Revival Audio Atalante 3 review | What Hi-Fi? (whathifi.com)
HIFI+
Revival Audio Atalante 3 stand-mount loudspeaker - hi-fi+ (hifiplus.com)
STATIV 5999 kr
ATALANTE 3 is a 2-way bookshelf speaker, equipped with the 28mm soft-dome tweeter and its built-in ARID (Anti Reflection Inner Dome) patented technology along with specialized back-chamber design, it can absorb over 95% resonance.
The first-ever in Hign-End BSC (Basalt Sandwich Construction) 7” woofer is the best balance found between rigidity and light-weight, with its great damping construction providing fast and smooth responses with tight bass dynamics.
You will be impressed by ATALANTE 3 with its compact size but exceptional BIG sound!
Type 2-way bookshelf loudspeaker
Drivers
1 1/8” (28mm) soft-dome tweeter equipped with Revival Audio ARID (Anti Reflection Inner Dome) patent technology with a large back chamber with low resonance frequency of 520Hz
7” (18cm) BSC (Basalt Sandwich Construction) woofer
Frequency Response (+/-3db) 44Hz – 22kHz (-3dB)
Sensitivity (2.83V/1m) 87dB/2.83V/1metre
Nominal Impedance 4 ohms
Minimum Impedance 4.4 ohms at 175Hz
Crossover Frequency 2.8kHz
Recommended Amplifier Power Power handling: 150 watts, starting from 30 watts.
Recommended Room Size 15 to 35 m2
Dimensions (H*W*D) 390 mm x 240 mm x 270 mm
Net Weight 11 kg. (24.25 lbs.)
ear
What HIFI
HIFI+
STATIV 5999 kr
Drivers
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
