Signalkablene i Regals Reference-serie benytter ledere av 99,99% Solid Core Silver og isolasjonsmateriale av PTFE. Regals unike Zero teknologi er benyttet for å redusere isolasjonsmaterialets negative innvirkning på lyden.
Tester gjort av våre kunder og oss indikerer at dette er en kabel med svært gode egenskaper til en, i high-end sammenheng, overkommelig pris. Kablene fremstår som transparente og velbalanserte. Hjemlån forut for et eventuelt kjøp er mulig.
Pris: NOK 16 380,- (for 1 stk DIN til RCA tonearmskabel på 1,25m lengde)
Frakt: Gratis (ved hjemlån dekker vi fraktkostnader 1 vei)
Produktside: Zero Reference (velg Reference serien og scroll helt ned)
Vår artikkel om Regal: Regal Audio kabler hos Gjallarhorn
Phono DIN-RCA
Moving coil cartridges delivers a very low signal level while moving magnet cartridges has a high output impedance. We took the challenge to be able to deliver very high performance with any type of cartridge. The high output impedance of MM cartridges enforce a very low cable capacitance. We use our latest generation of pure silver and reduced load capacitance geometry to get market leading performance. Regardless of price point. The result is a cable capacitance from only 24 pF/m depending on the choice of connectors.
The use of Zero technology for phono cables provides several advantages compared to traditional phono cables:
– Zero technology provides a shielding layer in itself. This without adding any capacitive load on the signal. The combination of good shielding and lowest possible capacitance is critical for the sound performance of a phono cable.
– Zero technology preserve the audio signal with a precision that is significantly more accurate than what traditional cable designs achieve. As signal losses that normally occurs due to polarization in the insulation material are cancelled by Zero technology, this cable delivers a new level of transparency with respect to level, timing and preservation of micro details.
Phono DIN-RCA
- Rhodium over silver plated oxygen free copper
- Teflon insulation
- Straight or 90 degree angled DIN-connector with either RCA or XLR connectors
- Rhodium/Gold over silver plated oxygen free copper
- Teflon insulation Y-Spade Ground Connector
- Gold plated Cabling
- Shielding
- Very light and flexible
- Conductor of solid core high purity silver
- Patent pending Zero technology
- Separate ground cable
- 1.25 m length
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
