JK
PS Audio P5 Strøm Regenerator/Strømfilter "Reservert" Solgt
Strømfiltere
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Hordaland
Pris
Kr 17.000
Annonse beskrivelse
Annonse nummer: 254352
Selger en PS Audio Strøm Regenerator/Strømfilter som er som ny da denne bare har vert i bruk under 1 år. Ble kjøpt i midten av September 2024 fra dødsboet etter importøren/forhandler av PS Audio Norge. Dette var en "overligger" fra lageret og var forseglet i original forpakningen da jeg kjøpte den.
Hos meg har denne uniten fungert fantastisk i et stort High-End Hodetelefon anlegg, men selges da jeg trengte flere utganger og jeg har oppgradert til en lik større unit.
"The PS Audio PerfectWave P5 Power Plant produces pure and perfect AC and is the power source of choice for almost any size system. Smaller than the P10, this workhorse of a product should be the foundation on which you build your system when a P10 isn’t in the cards.
The P5 Power Plant has 1250 watts of pure regenerated power handling any size system you want to power. From medium to large power amplifiers to the smallest pieces of source equipment, the P5 will work magic on your system’s performance. Dynamics and openness are breathtaking with the P5. This is clearly one of the most important pieces of audio equipment you can own."
"The Digital Signal Processing that PS Audio uses to generate a new AC sinewave in the Power Plant models has a 16-bit, rather than 8-bit, DAC. They have also improved the software-based phase locked loop (PLL) circuit to make the Power Plant more tolerant of phase issues. The new regenerator can also cope with a wider range of incoming voltages: it can deliver a steady 220 to 230 VAC, while the power coming from the wall can vary between 190 and 275 VAC. However, I doubt that most of us in the UK see even a ten per cent swing. While the technology behind the regeneration process is digital the output stage is essentially a Class A/B analogue power amplifier that, in the case of the P5, has a 1250 VA output. "
Selger denne nesten "nye" NOS strømregulatoren for 17000.- + frakt. Nypris på denne var 47000.- etter hva jeg kan finne ut da denne ble erstattet.
Kan sendes for kjøpers kost og ansvar.
Technical Specifications :
Output: 1250 VA
Features: Surge protection
Spike protection
Regulated output voltage
100% regenerated AC
Integrated oscilloscope
THD meter
Control over the web or network
Adjustable output voltage
Dimensions: W 430mm H 115mm D 360mm
Weight: 24kg
Originalemballasje
Ja
Orig. kvittering
Nei
Forsendelse
Avtales nærmere
JK
Torget karakterer
Vurderinger (11)
Andre annonser av JK
