Pent brukt Pioneer U-05 DAC, forforsterker og hodetelefonforsterker selges rimelig. Dette er et premium produkt med flott byggekvalitet og en lydkvalitet som er svært bra. Den kan drive de fleste hodetelefoner på markedet. DAC-en har USB, coax og optisk inn. Støtter DSD over USB.
Denne boksen er et columbiegg; hodetelefonforsterker, DAC og forforsterker. Nypris var 8000.
D/A Converter Features
8ch Parallel Drive with SABRE32 Ultra DAC (ES9016S x 2)
USB Input (PCM): 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz, 352.8 kHz, 384 kHz (16, 24, 32 bit)
USB Input (DSD): 2.8 MHz, 5.6 MHz
COAXIAL/OPTICAL/AES/EBU Input: 32 kHz, 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz (16, 24 bit)
Minimum Jitter with Asynchronous Transfer
Digital Filter with 3 Modes (SHARP/SLOW/SHORT)
Lock Range Adjust Function for Reducing Jitter by Adjusting Lock Range Accuracy
DIRECT Mode for Faithful Reproduction of Original Sound
Audio Scaler for up to 384 kHz/32-bit Upsampling
Headphone Amplifier Features
Shielded Power Transformer with Independent Winding, Isolated Power and Digital/Analogue Blocks
Full Balance Circuit for Minimum Noise
Discreet Circuit Adopted for High-Quality Sound Tuning
Balanced Headphone Terminal (XLR3/XLR4) x 2 Compatible with Recabled Headphones, Unbalanced Headphone Terminal (STD) x 1
Fine Adjust Volume Control
Gain Switch for Using Headphones with Different Impedance
Audio Performance and Various Other Features
Digital Isolator for Reducing USB Block Noise
Highly Renowned NEUTRIK Balance Terminals and Machined RCA Terminals
High-Grade Parts Including Pioneer Custom Power Capacitor
Variable/Fix Volume Selectable Analogue Output (XLR3/RCA) for Pre-Amp Function
Phase Switch Feature for Line Output
Low Centre of Gravity Design with Heavy and Robust Chassis
Screw-less Flat Design with Aluminium Front, Top, and Side Panels
Dedicated Remote for Volume and Tone Control
Front Display for Detailed Source Information
- Originalemballasje
- Nei
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
