Selger mine strøkne Paradigm studio 100 v5. Kjøpt nye i 2016
sakser litt specs fra produsenten
FREQUENCY RESPONSE ON-AXIS±2dB from 45 Hz - 22 kHz
HIGH FREQUENCY DRIVER25-mm (1 in) G-PAL™ dome, ferro-fluid damped / cooled, die-cast heatsink chassis, IMS/SHOCK-MOUNT™
MID/BASS FREQUENCY DRIVER178-mm (7 in) S-PAL™ cone, 38-mm (1-1/2 in) voice-coil, AVS™ die-cast heatsink chassis, IMS/SHOCK-MOUNT™
LOW FREQUENCY DRIVERThree 178-mm (7 in) mineral-filled polypropylene cones, 38-mm (1-1/2 in) voice-coils, AVS™ die-cast heatsink chassis, IMS/SHOCK-MOUNT™
SENSITIVITY ROOM / ANECHOIC92 dB / 89 dB IMPEDANCECompatible with 8 ohms
WEIGHT78 lbs. (35.4 kg) DIMENSIONS HXWXD44.125" × 9.5" × 17" (112.1cm × 24.1cm × 43.2cm)
- Originalemballasje
- Nei
- Orig. kvittering
- Nei
- Forsendelse
- Må hentes
