Strøken integrert forsterker selges. Få tegn på bruk.
Dobbel original emballasje. Fjernkontroll (Som var ekstra utstyr som ny).
Kan sendes. Denne er på 2x120w og bruker det anerkjente 6H30 røret i forforsterkerdelen.
Egne bilder kommer, med den er som sagt meget pen...
http://www.opera-consonance.com/products/PDF/manual/Reference/R150LINEAR 08-6.pdf
Specification |
Power output 120W +120W at 8 Ohms Minimum load 2ohms speakers can be connected. Input Sources 4 selectable inputs switched by gold plated relays Input Terminals Gold plated Phono/RCA unbalanced and gold plated XLR balanced Output Terminals One set of gold plated speaker terminals each channel Line level Outputs Gold plated Phono/RCA unbalanced pre out Frequency response Less than +/- 0.1 dB deviation 20Hz-80kHz Phase response Less than 2 degrees deviation 20Hz-80kHz Signal-to-noise ratio More than 100dB Crosstalk Less than -100dB Distortion Less than 0.04% @ 20W 80hms Inter-modulation Less than 0.01% (19kHz + 20kHz) Damping factor More than 800 Vacuum tube Sovtek 6H30 x1 Remote Control RC-5 compatible IR system 36kHz modulation Dimensions 12cm x 43cm x 32cm (HxWxD), 18kg shipment weight. |
- Originalemballasje
- Ja
- Forsendelse
- Kan sendes
