Konevennlig nett og liten strømmeforsterker med alt som hyter hele 2x150w i 8 ohm og 2x200w i 4 ohm. Du trenger kun ett par høyttalere og kabler så har du ett komplett anlegg. A300SE er en mere påkostet versjon av A200 for å gi en bedre lyd.Den kan også drivere mere krevende høyttalere.
The NuPrime Omnia A300SE is a full-featured multi-room streaming integrated amplifier (2 x 150W @ 8 ohms; 2 x 200W @ 4 ohms) capable of Wi-Fi 24-bit/192kHz and Bluetooth 5.0 aptX HD streaming. The Omnia A300SE includes multiple digital and analog inputs,
www.moetaudio.com
Tester:
www.hifipig.com
Feature Highlights
Streaming Hi-Res
Technical Highlights
A combination of high-power Class-D amplifier, 64-bit quad-core Arm Cortex-A53 processor, NuPrime proprietary SRC chip, Cirrus Logic CS43131 DAC, plus other audiophile-grade components enable the Omnia A300SE to achieve world class performance above its peers.
Amlogic A113X
for high resolution wireless streaming
Audiophile-grade components & noise filter
Bluetooth Wireless HD Qualcomm aptX HD supports 24-bit music quality over Bluetooth
The Omnia A300SE utilizes a compact yet powerful Class-D amplifier capable of signal bandwidth up to 100kHz with advanced integrated feedback design and error correction for very low noise and distortion. The Cirrus Logic CS43131 combines a next-generation, low power audio DAC with a high-fidelity headphone amplifier to provide a superior system-level audio performance. The onboard low noise, ground-centered headphone amplifier provides proprietary AC impedance detection to support headphone fingerprinting to provide a consistent and transparent audio experience for the end user regardless of transducer impedances or frequency responses.
SPECIFICATIONS
Amplifier
Dimension and Weight
Omnia A300SE
Tester:
NuPrime Omnia A300 SE Streaming Amp & DAC | Hifi Pig
NuPrime Omnia A300 SE is an all in one streaming amplifier with an onboard DAC.
NuPrime Omnia A300 review: an ultra-powerful connected HiFi mini amp that energizes music - NuPrime Audio
- Pierre Stemmelin, on-mag.fr "...The NuPrime Omnia A300 is an atypical connected Hifi amplifier open to all the most modern music sources. Beneath its very compact armored chassis, it hides a fiery temperament. Its 2 x 150 watts of power allow it to power large speakers, push the level of...
nuprimeaudio.com
Feature Highlights
- Amplifier capable of 2 x 150W @ 8 ohms and 2 x 200W @ 4 ohms power
- Wi-Fi 24-bit/192kHz and Bluetooth 5.0 aptX HD streaming. Mobile devices can stream Bluetooth music to Omnia A300SE, but it can not stream to Bluetooth earphones.
- Multiple digital and analog inputs, with up to IIS 32-bit/768kHz, USB 24-bit/384kHz, and DSD256 decoding
- Coaxial, Optical and analog Pre-Out
- Supports all major online streaming services (Amazon Music, iHeartRadio, Qobuz, QQ Music, Spotify*, TIDAL*, TuneIn, Napster, Ximalaya), AirPlay 2, and network DLNA
Streaming Hi-Res
- Supported "CD Quality" Streaming Services: Tidal HiFi
- Supported Hi-Res Streaming Services: Qobuz Hi-Res, Tidal Master
- Spotify Connect and TIDAL Connect are supported.
- Deezer HiFi is not supported
Amlogic A113X
SPECIFICATIONS
Amplifier
- Power: 150W @ 8 ohms; 200W @ 4 ohms (both channels driven)
- THD:
- <0.02% (AUX IN, 1W, @ 8 & 4 ohms)
- <0.01% (OPT IN, 1W, @ 8 & 4 ohms)
- Signal-to-Noise Ratio: >95 dB (Digital input, 10W out @ 8 ohms)
- Clipping Power: >230W (1kHz @ 4 ohms, both channels driven)
- Frequency Response: +0.6 dB/-1dB (12 Hz – 22 kHz)
- Channel Separation: >85dB (1 kHz AUX); >105 dB (10 kHz Digital)
- Input Sensitivity:
- 0.85V (AUX & OPT) for 100W @ 8 ohms
- 0.75V (AUX & OPT) for 100W @ 4 ohms
- Standby Power: <0.5W
- Bit Depths: 16-32 bit
- Streaming Audio Processing Engine: up to 192KHz / 24-bit
- IIS/DSD HDMI Input: PCM up to 768KHz/32Bit and DSD up to DSD256
- USB PCM/DSD Input: PCM up to 384kHz/32Bit and DSD up to DSD256
- Optical S/PDIF Input: PCM up to 192KHz and supporting DoP format DSD64
- Optical, Coaxial and analog Pre-Out
- Bluetooth: Receiving only**
- Network Connectivity: Gigabit Ethernet RJ45, 802.11 b/g/n Wi-Fi
- Product Dimensions (W x H x D): 280 x 55 x 250 mm (includes feet and extended rear panel terminals)
- Product Weight: 3 kg (6.6 lbs.)
- Package Dimensions (W x H x D): 440 x 100 x 340 mm
- Shipping Weight: 5 kg (11 lbs.)
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
