Moiz Audio
Butikk Mytek Stereo 192-DSD DAC Solgt
Denne annonsen er utgått.
D/a konverter
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Pris
Kr 9.000
Kjøpt av
hexachordia
Annonse beskrivelse
Annonse nummer: 47639
En meget populær DAC som kan spille av DSD filer. Annonsen gjelder preamp versjonen.
DSD er den nye standarden for høyoppløselig "analog" lydende filformat.
nypris: 12500
2014 Recommended Components - Stereophile Magazine
2013 TAS Golden Ear Awards
http://www.highfidelity.pl/@main-421&lang=en
http://www.head-fi.org/t/622248/myte...ciation-thread
info:
http://moiz.no/produkter/mytek-digit...2-dsd-dac.html
The Mytek Stereo 192-DSD Digital to Analog Converter is an ultra-transparent mastering grade digital audio playback system.
Designed around state of the art Sabre 32 bit conversion technology, the Stereo 192-DSD DAC delivers features and sound quality beyond expectation of the most
discerning of listeners.
The DAC is capable of converting high
resolution PCM audio up to 192 kHz sample rates, as well as DSD, all through high-speed USB 2.0 or FireWire.
For the ultimate "plug and play" solution, a USB 1.1 port is available
for a driver-less connection to your computer that can handle PCM audio up to 96 kHz sample rates.
The "Mastering" version of the DAC has DSD SDIF inputs that can be used to connect professional DSD systems. The
"Preamp" version has a pair of RCA analog inputs instead of the DSD inputs so you can use the DAC as a preamp.
The "Preamp" model is also available in a silver front panel version that has the signal level LEDs removed for a cleaner
look. These LEDs can also be disabled in the menu on the black panel versions.
Features
32 bit ESS Sabre DAC (8 mono to 2 stereo configuration)
* Native 192kHz PCM and DSDx64/DSDx128 conversion
* Ultra-low jitter (10 picosecond) internal clock generator
* Internally up-sample and eliminate jitter from PCM to
192kHz/24bit prior to conversion (can be disabled)
* Sharp and Slow PCM Filters; 50kHz/60kHz/70kHz
DSD Filters
* Transparent Analog or Digital stepped volume control
with Bypass for the purest signal path
* Independent control of Main Outs and Headphones
* High Current, High Slew Rate ultra low distortion
500mA audiophile headphone amp
* AES/EBU, S/PDIF, Toslink digital inputs
* FireWire400, USB2.0, USB1.1 computer interface
* DSD SDIF input or Analog input
* Wordclock In/Out
* Universal Remote Compatible
* 115/230V switchable linear power supply
Moiz Audio
Torget karakterer
Vurderinger (126)
Andre annonser av Moiz Audio
