D
Musical Fidelity KW750
Denne annonsen er utgått.
Effektforsterker
Selges
Tilstand
Brukt
Utløpsdato
Fylke/land
Buskerud
Pris
Kr 29.000
Annonse beskrivelse
Annonse nummer: 244480
Har du kjent litt på at du skulle hatt ørlite ekstra power på forsterkeren din i det siste? Da kan du jo vurdere denne.
Forsterkeren fungerer utmerket. Det finnes tester på nettet.
Output : Power : 750 Watts per channel into 8 Ohms (29dBW),
1100 Watts per channel into 4 Ohms
Voltage, RMS : 77.5 Volts 20Hz to 20kHz
Voltage, peak-to-peak : 219 Volts
Current, peak-to-peak : 250 Amps
Damping factor : 204
Output devices per channel : 20
Loop out impedance : 50 Ohms
Line inputs :
Total harmonic distortion + noise : < 0.004% 20Hz to 20kHz
Signal / noise ratio : > 124dB ‘A’-weighted
Input sensitivity for 750 Watts into 8 Ohms : 2.4 Volts
Input impedance : 100k Ohms
Channel separation : > 93dB typical
Frequency response : 20Hz to 20kHz, +0, -0.2dB
Input : 1 pair line level RCA connectors
Outputs : 2 amplifier channels via 2 pairs per channel binding posts,
1 pair RCA loop output sockets
Power requirement : 100 / 115 / 230Volts AC 50 / 60Hz (factory pre-set),
2500 Watts at maximum audio power into 8 Ohms, 290 Watts idle
Dimensions : Amplifier : 483 mm, 19 inches wide
167 mm, 21.8 inches high including feet
553 mm, 15.75 inches deep including rear terminals
Power supply : 364 mm, 14.4 inches wide
167 mm, 6.6 inches high including feet
278 mm, 11 inches deep including rear sockets
Weight : Amplifier : 34.1 kg, 75.1 lbs unit only, unboxed,
45.2 kg, 100 lbs in shipping carton
Power supply : 18.4 kg, 40.6 lbs unit only, unboxed,
21.4 kg, 47.2 lbs in shipping carton
Standard IEC mains lead - (16-Amp type) : one, 2.4 metres (94.5 inches)
accessories : Low voltage interconnection leads : two, 1.2 metres (47.3 inches)
Control interconnection lead : one,1.2 metres (47.3 inches)
Originalemballasje
Ja
Orig. kvittering
Nei
Forsendelse
Må hentes
denis
Torget karakterer
Vurderinger (3)
