Pent brukt Lumin D2 streamer og DAC i sort utførelse selges. Spilleren er teknisk strøken og bortimot kosmetisk strøken. En liten skrape på bakpanelet og en ørliten skramme til høyre for displayet er alt som synes uten lupe. Jeg er eneste eier og har både originalemballasje og kvittering. Kan sende for kjøpers regning og risiko.
Nypris var 26990,-
Gode tester overalt på nettet. Her, feks:
www.head-fi.org
www.hifireport.com
Spesifikasjoner:
Nypris var 26990,-
Lumin D2 - Reviews
Lumin D2 Review – HiFiReport
Spesifikasjoner:
- DSD Support:
- Up to DSD128 5.6MHz, 1-bit
- PCM Support:
- Up to 384kHz, 16–32bit, Stereo
- Upsampling rates & bit depths:
- DSD upsampling option for all files up to 96kHz
- PCM 192kHz upsampling option for all files up to 96kHz
- Analog Output Stage:
- Wolfson WM8741 DAC chips, 1 chip per channel
- Fully balanced layout with high-quality components
- Digital Output Stage:
- BNC SPDIF:
- PCM 44.1kHz–192kHz, 16–24-bit
- DSD (DoP, DSD over PCM) 2.8MHz, 1-bit
- BNC SPDIF:
- Power Supply:
- Internal 100–240V AC auto-ranging
- Physical:
- Finish:
- Raw brushed aluminium or black anodised brushed aluminium
- D2 unit:
- 300mm (W), 244mm (D), 60mm (H), 2.5kg
- Packaging:
- 470mm (W), 340mm (D), 170mm (H), 4.5kg
- Finish:
- Streaming Protocol:
- UPnP AV protocol with audio streaming extension (OpenHome)
- Roon Ready
- Spotify Connect
- Plāys with Audirvāna
- JPLAY Certified
- AirPlay-compatible
- QPlay-compatible for QQMusic
- Gapless Playback
- On-Device Playlist
- App Features:
- Native support for TIDAL, MQA, Qobuz and TuneIn Radio.
- Tidal MAX and MQA icons to identify high-res music
- Qobuz high-res icons to identify high-res music
- Volume control
- High-resolution artwork
- Artwork caching
- Search
- Multiple tag handling
- Composer tag support
- Album-grouping in playlist
- Automatic internet links to artists/album/songs
- Saving and restoring of playlists (including Tidal and Qobuz)
- Supported Audio File Formats:
- DSD Lossless: DSF (DSD), DIFF (DSD), DoP (DSD)
- PCM Lossless: FLAC, Apple Lossless (ALAC), WAV, AIFF
- Compressed (lossy) Audio: MP3
- MQA
- Input:
- Ethernet RJ45 network 1000Base-T
- USB storage, flash drive, USB hard disk (Single-partition FAT32, exFAT and NTFS only)
- Analogue Audio Outputs:
- XLR balanced, 4Vrms, pin 2 Hot
- RCA unbalanced, 2Vrms
- Supported Control Devices:
- Apple devices. iOS 11.0 or later (List of supported devices)
- Android devices. Android 6.0 (Marshmallow) or later required
- Apple Silicon. macOS 11 or later. (Download the iOS App from the iOS App Store)
- Chromebook. Google Play Store required.
- Other:
- Leedh Processing lossless digital volume control
- Programme of Continuous Development – Firmware-upgradable for further features and enhancements
- Originalemballasje
- Ja
- Orig. kvittering
- Ja
- Forsendelse
- Kan sendes
